Peltier Cooler connected to Power Supply, is this configuration safe?
In summary, the conversation discusses building a Peltier Cooler with the use of a battery as the power supply. The concern is that the Peltier coolers, which are rated at 30A, may draw too much current and potentially damage the power supply. The suggestion is to use a current limiter or estimate the resistance of the cells in order to ensure the current is less than 30A. It is also advised to use a heatsink on the hot side of the Peltier devices to dissipate heat.
Link
134
I am building a Peltier Cooler with the circuit diagram below. The power supply will be a battery, but for testing purposes I am connecting it to a stationary power supply.
http://dl.dropbox.com/u/10419947/circuit.png
I suspect that the peltier coolers which are rated at 30A will draw as much current and power as possible once I switch the power supply on, potentially destroying the supply itself even though I do not intend to deliver anything above 10 A. Are my fears warranted? I prefer not to try my luck as the power supply costs a fortune to replace.
Thanks in advance.
➤ Some power supplies have a current limiter so you can set the max current.
➤ Do you have manufacturer's technical data that indicates how many volts the Peltier devices need for 10A?
You have the coolers in series, so each will get 3.5 volts maximum.
You can estimate the resistance of the cells by working out the resistance under full power.
R = E / I so R = 14 volts/ 30 amps = 0.4 ohms. (This is just an estimate because these devices may not be linear. I tried a lower powered Peltier and it was linear, though.)
So, if you just put 4 of these in series across 14 volts, you would get a current of 14 volts / (4 * 0.4 ohms) or 8.75 amps. So, the current switched by the MosFet should be less than this.
Much less than their 30 amp rating.
So, the Peltiers should be OK.
You could put a 10 amp fuse in series with the Peltiers to make sure the power supply is not overloaded.
Your symbol is for a NPN transistor.
Peltier devices get hot on one side and cold on the other side, so you have to have a heatsink on the hot side to carry the heat away.
Related to Peltier Cooler connected to Power Supply, is this configuration safe?
1. Is it safe to connect a Peltier Cooler directly to a power supply?
Yes, it is generally safe to connect a Peltier Cooler to a power supply. However, it is important to ensure that the power supply is compatible with the cooler and that the correct voltage and current are being supplied.
2. Can a Peltier Cooler cause a short circuit when connected to a power supply?
No, a Peltier Cooler itself does not have the capability to cause a short circuit. However, if the power supply is not properly regulated or if the cooler is damaged or wired incorrectly, it could potentially cause a short circuit. It is important to follow proper safety precautions when working with any electrical equipment.
3. What are the risks of connecting a Peltier Cooler to a power supply?
The main risk of connecting a Peltier Cooler to a power supply is the possibility of overheating or damaging the cooler if the voltage or current is too high. It is also important to ensure that the cooler is properly insulated and secured to avoid any electrical shocks or hazards.
4. How do I know if my power supply is compatible with a Peltier Cooler?
It is important to check the specifications of both the power supply and the cooler to ensure compatibility. The power supply should have a suitable voltage and current output for the cooler, and the cooler should be able to handle the power supply's maximum output. It is also recommended to consult the manufacturer's instructions for both the power supply and cooler before connecting them.
5. Are there any precautions I should take when connecting a Peltier Cooler to a power supply?
Yes, there are a few precautions to keep in mind when connecting a Peltier Cooler to a power supply. First, make sure the power is turned off before making any connections. Then, double check that the voltage and current output of the power supply are correct for the cooler. It is also important to ensure that all connections are secure and that the cooler is properly insulated to avoid any potential hazards.
  • Electrical Engineering
