Suppose there is a semiconductor with Fermi energy
In summary, the mean number of excited electrons in a semiconductor with Fermi energy $E_f$ and $N$ bound electron states takes the form \bar n(T)={N\over \exp\beta(\mu-E_f)+1}, where \mu is the chemical potential. This is based on the Fermi Dirac statistics, which state that for one fermion the mean occupation number is \bar n = {1\over \exp\beta(E-\mu)+1}. By changing the places of Ef and E, the expression can be simplified to the given form. However, this approximation does not work well for heavily p-type semiconductors.
c299792458
71
Suppose there is a semiconductor with Fermi energy $E_f$ and that there are $N$ bound electron states.
I'd like to know why the mean number of excited electrons takes the form [tex]\bar n(T)={N\over \exp\beta(\mu-E_f)+1}[/tex]
where [itex]\mu[/itex] is the chemical potential.
____
I can see that the Fermi Dirac statistics say that for one fermion the mean occupation number is [tex]\bar n = {1\over \exp\beta(E-\mu)+1}[/tex]
I am not sure however as to how for the semi-conductor it should assume the above form. The N is clearly due to the [itex]N[/itex] bound [itex]e^-[/itex] states. I am not quite so confident as to why [tex]\mu\to E_f, E\to \mu[/tex]
Could someone please explain?
Many thanks.
i think by E, you mean the top of the valence band?
Every electron that is not bound is excited (or makes a "hole" in the valence band and an electron in the conduction band).
There are N bound states, so the number of excited electron is N* (1- fermi_dirac_dist(E))
mathematically, this is the the same as changing the palces of Ef and E, try it.
By the way, using E as the top of the valence band is an approximation which doesn't work if, for example, the semiconductor is very heavily p-type.
Thank you, Giga_Man!
What is Fermi energy?
Fermi energy refers to the highest possible energy level that an electron in a solid material can have at absolute zero temperature. It is a measure of the energy required for an electron to move from the highest filled energy state to the lowest available empty energy state.
How does Fermi energy affect the properties of a semiconductor?
Fermi energy plays a crucial role in determining the electrical and optical properties of a semiconductor. It affects the number of charge carriers (electrons and holes) in the material, as well as their distribution and mobility. It also determines the band gap, which is the minimum energy required for an electron to move from the valence band to the conduction band.
Can the Fermi energy of a semiconductor be manipulated?
Yes, the Fermi energy of a semiconductor can be manipulated through various means such as doping, applying an external electric field, or changing the temperature. This allows for control over the number of charge carriers and their behavior, making it possible to tailor the properties of the semiconductor for specific applications.
What is the significance of the Fermi level in a semiconductor?
The Fermi level, which is the energy level corresponding to the Fermi energy, is a key parameter in understanding the electronic properties of a semiconductor. It determines the probability of finding an electron at a particular energy level and plays a crucial role in determining the conductivity and band structure of the material.
How is Fermi energy related to the concept of energy bands in a semiconductor?
Fermi energy is closely related to the energy bands in a semiconductor. The energy bands refer to the allowed energy levels for electrons in a solid material. The Fermi energy marks the boundary between the highest filled energy band (valence band) and the lowest available empty energy band (conduction band). The size of the band gap, as determined by the Fermi energy, determines the conductivity and other properties of the material.
  • Atomic and Condensed Matter
