Why does wet wool insulate while wet cotton does not insulate?
  • Thread starter Emperor25
In summary: This means that wool can absorb moisture without becoming wet to touch. As the fibres naturally repel each other, an amount of air is retained which provides an insulation effect.In summary, wool clothes have the ability to insulate a person even when wet due to the kinked shape of their fibers, the natural oil on the fibers that repels water, and the retention of air pockets within the fabric. Unlike cotton, which wicks water and loses its insulating properties when wet, wool maintains its insulation abilities thanks to these unique characteristics. Additionally, the surface energy of wool is 10 times lower than cotton, allowing for water to be absorbed without making the
Emperor25
Cotton clothes do not insulate a person when they are wet, but wool clothes still do insulate a person when they are wet.
What is the difference between cotton and wool that allows one to insulate while wet while the other can't?
Computer science news on Phys.org
The insualtion comes from trapped air.
Wool has natural oil on the fibres so that the water tends to bead on the surface leaving lots of air in the material.
With thinner cotton the water wicks straight through, giving nice thermal conducting water path from the skin to the outside.
It has to do with the fibers. Cotton wicks water and holds it in, and any air spaces fill up, so you stay wet and cold. Wool has kind of kinky fibers that make wool itchy and scratchy but maintain some air spaces even when wet. It's easier to wring water out of wool, too.
Two more questions.
Why doesn't the natural oil on the fibers of the wool wash off/wear off or otherwise leave the wool fibers over time?
Would a sweater that is a blend of 50% cotton and 50% wool still insulate when it was wet?
Emperor25 said:
You explanation mostly makes sense, except that one would expect that the natural oil on the fibers of the wool would wash off/wear off or otherwise leave the wool fibers over time.
It does - that's why you don't wash wool heavy jumpers if you want them to stay warm and waterproof.
I thought that wool is never waterproof.
mgb, do you agree with the posted quote below?
"Wool is a Hygroscopic Insulator
This means that wool can absorb moisture without becoming wet to touch. Wools natural insulation ability is not affected by moisture because of its built in natural crimp. As the fibres naturally repel each other, an amount of air is retained which provides an insulation effect."
http://www.naturalwoolproducts.co.nz/SITE_Default/whywool.asp
Do the wool fibers naturally repel each other because of the natural oil on the wool fibers?
Wool is hydrophobic - the surface energy of wool fibres is about 10x lower than cotton (wool is almost as good as polyprop).
Cotton fibres branch out into tiny feather like fibres that attract water, wool is smother, almost like polyester on a microscopic scale. I'm not sure how much the large shape of the fibres effect this - although it does mean the garment has more thickness to trap air.
But wicking is different to transferring water vapour so wool is also breathable.
I am not a scientist.
I've never heard of materials having surface energy before. The closest thing I can think of related to this is Einstein's equation E= Mc squared. In other words, I don't understand the signifigance of saying that the surface energy of wool fibers is 10x lower than cotton. I don't understand how surface energy relates to insulation.
Only if there is only one layer of atoms to the fabric, which there isn't.
I don't know what wicking means.
Surface energy means the energy of the bonds on the surface of a material.
Imagine a drop of water, each water molecule has a choice of wether to bond to other water molecules around it and form a droplet or instead to bond to the surface of the material it is sitting on and wet it.
Everythign wants to be in it's lowest energy state and since breakign the bonds to the other water molecules takes energy the water will only wet a surface if the energy it will gain by making these new bonds is greater than the cost of breakign the ones inside the droplet. Water has very strong bonds to other water molecules so it will only wet materials with quite high surface energies.
That's why on most materials, like glass or metals, you see water as droplets.
If you have a material with a very high surface energy it is even possible for water to travel uphill to make those new energetic bonds - that's what happens when you put the edge of a piece of tissue paper in water and the water runs up the tissue to wet all of it - that's wicking or capilary action.
"As the [wool] fibres naturally repel each other, an amount of air is retained which provides an insulation effect."
Do wool fibers naturally repel each other because wool fibers have low surface energy?
If wool fibers' having low surface energy is not the reason that wool fibers naturally repel each other, why do wool fibers naturally repel each other?
Do wool fibers naturally repel each other because of the oil on wool fibers?
I don't thick that wool fibres repel each other - it's more that their kinked shape keep the fibres from lying flat together. This gives wool it's loft - why wool yarn is fluffy rather than thin and smooth. You can make wool into a smooth flat material without any trapped air (ie. felt) but it takes a lot of hammering to flatten out the fibres.
Molecular attraction / repulsion only works on very short distance - like a molecule sticking to a surface.
Does wool have a surface energy ten times lower than cotton because of the natural oil on the wool fibers?
mgb, In light of what you've told me, it seems to me that wool insulates when it's wet for the following three reasons: (1) the kink shape of wool fibers makes larger air pockets inside the fabric and (2) the natural oil on wool fibers makes water tend to bead up on the outside of wool rather than occupy the air pockets in wool and (3) wool has a lower surface energy than cotton.
I would think wool's surface energy is an intrinsic property of the surface rather than any oils - although adding oil as well will help.
The chemistry of wool and cotton is very different. Wool is a protein similair to the stuff that makes up your finger nails while cotton is a sugar although they look the same when made into clothers they are from opposite ends of biology.
If the natural oils on the wool fibers are completely washed away, will wet wool clothes still insulate better than wet cotton clothes?
Yes because the water will still tend to bead rather than wet the material ( due to surface energy)
The kinked wool fibres create more air spaces between fibres.
The wool garment generally has more thickness of material to trap air especially if it is knitted rather than woven.
mgb, if someone walked around in an extremely heavy rain for an hour wearing a wool sweater without the natural oils, after an hour wouldn't the wool sweater become saturated with water with the air spaces filling up with water too?
Probably (especially without the oils) although it is very difficult to saturate wool, even holding it under water it takes a lot of effort to get all the air out, it might take more than an hour to saturate! Walking makes it worse - the movement squeezes the water between the fibres.
With the oils - like a traditional fishermen's jersey it's hard to beat except for really good modern tech fabrics. Next to your skin as a base or mid-layer something like fine merino wool or wool-silk mix is still unbeatable by any modern fabric.
mgb, the reason that I'm asking these questions is I'm considering buying some wool pants to keep me warm this winter. I wanted to buy wool pants so my legs would still be insulated if I got wet while walking in the rain. When you told me about how the natural oils in the wool can be washed off the wool when one washes wool clothes in the wash machine, my reaction was to think that I should not buy wool pants because they would not have superior insulating properties compared to cotton pants after they got wet. In light of what you've told me however, it seems that wool pants will keep their insulating properties when wet indefinitely.
Conclusion: I should buy the wool pants.
If all the air pockets in a wool sweater did somehow become saturated with water, couldn't a person just squeeze and twist the sweater to wring the water out of it and the air pockets would open up again?
I see - I thought this was a chemistry/material science question!
Wool pants wil be a 100x better than jeans.
The best principle is usually layers, so if it's cold some padded/lined pants and water proof overpants (ideally Gortex). The best thing with wool is to wash it as little as possible - it gets a lot less semlly than synthetics anyway.
Yes you can squeeze water out of wool, but if it is going to get that wet you are probably better off with polypro-fleece or something water proof over the top.
1) Why does wet wool insulate better than wet cotton?
Wool is a natural fiber that contains crimped or wavy strands. When wet, these strands are able to trap air pockets, which act as insulators. Cotton, on the other hand, does not have this same crimp and therefore does not trap air as effectively when wet.
2) How does the structure of wool contribute to its insulation properties?
The crimped structure of wool fibers creates a network of air pockets that trap heat and prevent it from escaping. This structure also makes it difficult for water to penetrate the fibers, keeping the insulation properties intact even when wet.
3) Does the thickness of the wool affect its insulating abilities when wet?
Yes, the thicker the wool, the more air pockets it can create and the better it can insulate when wet. This is why thicker wool garments, such as sweaters or coats, are more effective at keeping the body warm even when wet.
4) Is there a difference between the insulation properties of natural and synthetic wool when wet?
Yes, natural wool tends to maintain its insulating abilities even when wet, while synthetic wool may lose some of its insulation properties when wet. This is because natural wool has a more complex structure that is better at trapping air and water, while synthetic wool is typically made of straighter fibers that do not trap air as effectively.
5) Can wet cotton still provide some insulation?
While cotton does not insulate as well as wool when wet, it can still provide some degree of insulation. This is because cotton fibers can absorb water, which then heats up from body heat, providing some warmth. However, this insulation is minimal compared to the insulation provided by wet wool.
  • Other Physics Topics
  • Electromagnetism
  • General Discussion
  • Classical Physics
  • Electrical Engineering
