True or false: If it's true, give an example. If it's false, prove it.
  • Thread starter davitykale
  • Tags
    Example
In summary, a function f: R -> R is continuous at a point c if and only if c is not an element of the set { m\2^n: m,n in Z, n>=0}. This can be shown by defining a piecewise function where f(x) = 0 if x is an element of the set, and f(x) = x otherwise. However, this does not hold true as the set is dense and there is an irrational number in every neighborhood of the points in the set. Therefore, c is not continuous at points of the form m/2^n and the function is only continuous at irrational numbers.
davitykale
38
A function f: R -> R such that f is continuous at a point c if and only if c is not an element of the set: { m\2^n: m,n in Z, n>=0)
Definition of continuity/discontinuity?
Is it enough to say that we can define a piecewise function where f(x) = 0 if x is an element of the described set, and f(x) = x otherwise...then we maybe have continuity at points such as irrational numbers?
I would be if you could prove it. But you can't. The set you've defined is dense. It doesn't work. Try f(m/2^n)=1/2^n for points in the set and zero otherwise.
I think I'm confused...wouldn't that mean that c is continuous when it is an element of the given set?
No, it's not continuous at points of the form m/2^n. There's an irrational in every neighborhood of one of those points.
What does "True or false" mean?
"True or false" refers to a type of question that requires a person to determine if a statement is true or false. It is often used in tests, quizzes, and surveys to assess knowledge or opinions.
What is an example of a "true" statement in this format?
An example of a "true" statement in this format is "Water boils at 100 degrees Celsius at sea level." This statement is true because it is a well-established scientific fact that can be proven through experiments and observations.
How can you prove that a statement is false?
To prove that a statement is false, you need to provide evidence or counterexamples that contradict the statement. For example, to prove that the statement "All mammals lay eggs" is false, you can point out that mammals such as dogs, cats, and humans do not lay eggs.
Can a statement be both true and false?
No, a statement cannot be both true and false. It can only be one or the other. This is because true and false are mutually exclusive states - something cannot be both true and false at the same time.
Why is it important to have a "true or false" format in scientific research?
The "true or false" format is important in scientific research because it allows for clear and concise communication of ideas and findings. It also allows researchers to test hypotheses and make conclusions based on evidence and facts, rather than opinions or beliefs.
