Cerebral hemispheres' control of opposite sides of the body
In summary, the majority of signals from the brain to the body and vice-versa cross over on their way to and from the brain, resulting in the opposite sides of the body being controlled by the opposite hemispheres of the brain. This phenomenon is seen in both vertebrates and invertebrates and is necessary for coordinating movements and responses. In mammals, the expanded cortex has allowed for new functions and the visual areas receive inputs from thalamic visual areas on the same side. However, the orientation of the visual field in the nervous system does not directly match that of the external world, but the nervous system is able to use transformations to generate appropriate movements. The mix of crossing and non-crossing fibers in the nervous system makes it difficult
grosquet
I am curious to find out why the 2 parts of the brain control the opposite sides of the body. This is the best I’ve found so far:
“For some as-yet-unknown reason, nearly all of the signals from the brain to the body and vice-versa cross over on their way to and from the brain. This means that the right cerebral hemisphere primarily controls the left side of the body and the left hemisphere primarily controls the right side. When one side of the brain is damaged, the opposite side of the body is affected. For example, a stroke in the right hemisphere of the brain can leave the left arm and leg paralyzed.“
( from http://www.ninds.nih.gov/disorders/brain_basics/know_your_brain.htm)
Does anyone know how far back this goes? I mean, did it get started with the most primitive vertebrate?
Biology news on Phys.org
Through both vertebrate and invertebrate nervous systems, there are many sets of fiber that cross the mid-line to the opposite side of the body. However not all fibers do this. This at least some crossing fibers are required to coordinate the opposite sides of the body.
An example is during walking, one legs goes forward as the other goes back. This requires anti-coordinating the motor neuron pools for leg muscles.
At higher levels, signals cross to generate avoidance responses, such as bending the body to move away from a loud noise, vibration, or touch.
Visual inputs from the retina to the midbrain (lateral geniculate or optic tectum) cross the body to the opposite side.
In frogs, the optic tectum receives also inputs from other sense modalities and brain areas and is involved in some orientation reflexes and startle reflexes, which are carrier out by via to motor and motor control areas in the hindbrain and spinal cord. some of these will be crossed fibers (to the other side) and some not.
In mammals, where cortex is greatly expanded, with new functions. The visual areas receive large inputs from thalamic visual areas on the same side.
The nervous system is mix of crossing and non-crossing fibers and assessing why a particular step is on one side and not the other is a difficult problem, but it does not seem to me to be surprising.
A related issue might be the orientation (top-bottom or nasal-temporal in the visual field axis vs. dorsal-ventral or medial-lateral in the tissue) of the visual field in the nervous system vs. in the real world. The representation in the nervous system does not directly match the external sensory sources, but this does not matter functionally, since the nervous system can use similar transformations to generate the appropriate movements.
1. How do the cerebral hemispheres control opposite sides of the body?
The cerebral hemispheres control opposite sides of the body through a process called contralateral control. This means that the left hemisphere of the brain controls the right side of the body, and the right hemisphere controls the left side of the body. This is because the nerve fibers from each hemisphere cross over to the opposite side of the body in the brainstem.
2. What is the purpose of having the cerebral hemispheres control opposite sides of the body?
The purpose of contralateral control is to allow for more efficient and coordinated movements. For example, when you want to reach for an object with your right hand, the left hemisphere of your brain will plan and initiate the movement while simultaneously inhibiting any unnecessary movements from the left side of your body.
3. Can a person's dominant hand be controlled by the non-dominant hemisphere of their brain?
Yes, it is possible for a person's dominant hand to be controlled by the non-dominant hemisphere of their brain. This is known as cross-dominance and is more commonly seen in left-handed individuals, as their right hemisphere is typically dominant for language and motor functions.
4. What happens if there is damage to one hemisphere of the brain?
If there is damage to one hemisphere of the brain, it can affect the contralateral side of the body. For example, a stroke in the left hemisphere can cause paralysis or weakness on the right side of the body. However, the unaffected hemisphere may compensate and take over some functions of the damaged hemisphere.
5. Are there any exceptions to the rule of contralateral control by the cerebral hemispheres?
Yes, there are some exceptions to the rule of contralateral control. Some cranial nerves do not cross over to the opposite side of the body, so they are controlled by the same hemisphere. Additionally, some reflexes may also be controlled by the same side of the brain, such as the pupillary reflex and the gag reflex.
  • Biology and Medical
19K
46K
29K
