Hertzian contact stress SS-2244 / AISI-SAE 4140
In summary, AISI-4140 Low Alloy Steel can withstand a maximum stress of 219 ksi before it begins to yield.
Ian06
Hello guys!
Is there anyone who knows where i can find information about maximum allowed Hertzian contact stress for material SS-2244 / AISI-SAE 4140 or any similar material quality?
I have been searching for this information in several Swedish books and material tables, without success.
Can you give us some more information on the potential failure mode?
AISI-4140 Low Alloy Steel at room temperature
F_tu = 150 ksi
F_ty = 132 ksi
F_cy = 145 ksi
F_su = 90 ksi
F_bru = 219 ksi
F_bry = 189 ksi
t = tensile; c = compressive; br = bearing; u = ultimate; y = yield
You need to define what your failure criteria is, especially with contact stresses.
A pin made of high grade spring steel is pressed tangential against the inside of a hub.
Pin diameter (r1) = 2,5 mm
Hub diameter (r2) = 55 mm (concave, and therefore -55 mm in Hertzian calculations)
Contact length = 40 mm
Hub material SS-2244 / AISI-SAE 4140
The objective is to "backwards" calculate the maximum force F (N) that can be applied without causing plastic deformation on the inside of the hub.
I´ll draw a simple sketch and add it tomorrow.
Unfortunately my english is rather bad.
F_tu = 150 ksi
F_ty = 132 ksi
F_cy = 145 ksi
F_su = 90 ksi
F_bru = 219 ksi
F_bry = 189 ksi
Thank you minger! Do you have any reference (book/website etc.) for this information?
F_tu = 150 ksi
F_ty = 132 ksi
F_cy = 145 ksi
F_su = 90 ksi
F_bru = 219 ksi
F_bry = 189 ksi
That seems awfully high for 4140 in the annealed state. Are you sure that isn't in some heat treated condition? The OP didn't mention anything about the final condition so this may be correct.
Oh, the 2.5mm (roughly 0.1") makes a difference. The spec I quoted was for 1" or greater...
Nope, that is for less than 1". It should be good if it is 4140. It seems that for smaller diameters, AISI-4130 is more commonly used, which is significantly weaker.
Some comments:
AISI 4130 is a chromium-molybdenum steel that is in general use due to its well-established heat-treating practices and processes techniques. It is available in all sizes of sheet, plate and tubing. Bar stock of this material is also used for small forgings under one-hal finch in thickness. AISI-4135 is a slightly higher carbon version of AISI 4130, is available in sheet, plate and tubing.
AISI 4140 is a chromium-molybdenum steel that can be heat treated in thicker sections and to higher strength levels than AISI 4130. This steel is generally used for structural machined and forged parts one-half inch and over in thickness. It can be welded but it is more difficult to weld than the lower carbon grade AISI 4130.
OK, so agreed Fred, without a little more material information, it's hard to tell. Let me get the other source. OK, 1" round bar has
Annealed - F_ty = 62ksi
Normalized - F_ty = 93 ksi
You're probably looking at a bearing strength, so for bar, forgings
Annealed - no data
Normalized - 158 ksi
Normalized and heat treated (with Ftu = 140) - 225 ksi
Normalized and heat treated (with Ftu = 160) - 252 ksi
Normalized and heat treated (with Ftu = 180) - 284 ksi
edit: Ian, my first source is a MIL spec manual called the MMPDS (Metallic Materials Properties Development and Standardization). It's a slightly more current version of something that was called...(something else can't remember). We just 'have' it, although I do know for fact that it is available from off of a website hosted by a Big10 school that makes a name for itself with engineering.
I also use the ASMD (Aerospace Materials Database), which we have both in several extremely large old books, and as an online website we need to log into.
So a value between 140-284 ksi will work as an approximation for calculations with the 2,5 mm pin?
I would say 158 ksi if its not heat-treated, 225 if it is.
Since you're doing Hertzian stress, you're probably going to need elastic modulus and Poisson's huh?
Yes please! :smile:
Related to Hertzian contact stress SS-2244 / AISI-SAE 4140
What is Hertzian contact stress?
Hertzian contact stress is the stress that occurs at the contact point between two objects under pressure. It is named after the German physicist Heinrich Hertz, who first described it in the late 1800s.
How is Hertzian contact stress calculated?
Hertzian contact stress can be calculated using the Hertzian contact theory, which takes into account the geometry, material properties, and applied load of the two objects in contact. It is typically calculated using equations such as the Hertzian contact stress formula or the Hertzian contact stress equation.
What is SS-2244 / AISI-SAE 4140?
SS-2244 and AISI-SAE 4140 are both types of steel. SS-2244 is a Swedish standard for a low-alloy steel, while AISI-SAE 4140 is an American Society for Testing and Materials (ASTM) specification for a medium carbon steel. They are both commonly used in industrial applications due to their high strength and durability.
How does Hertzian contact stress affect SS-2244 / AISI-SAE 4140?
Hertzian contact stress can cause deformation and damage to SS-2244 and AISI-SAE 4140 if the applied load is too high. The material's strength and hardness play a crucial role in determining how much stress it can withstand before failure. Therefore, it is important to consider Hertzian contact stress when designing or using components made from these steels.
What are some methods for reducing Hertzian contact stress on SS-2244 / AISI-SAE 4140?
There are several methods for reducing Hertzian contact stress on SS-2244 / AISI-SAE 4140, including using lubricants, increasing the surface area of contact, and using softer materials for one of the contacting surfaces. Additionally, proper design and engineering techniques can help distribute the load more evenly and reduce stress concentrations.
  • Mechanical Engineering
12K
  • General Engineering
11K
  • STEM Academic Advising
  • STEM Career Guidance
