What is the wavefunction of the localized particle?
In summary, the conversation discusses the use of the delta function in representing the wavefunction for a localized particle at position x_0. While the delta function has some mathematical issues, such as being non-normalizable and not following the rules for calculating expectation values, it is still commonly used in textbooks. The conversation presents alternatives, such as using the square root of the delta function or working with discrete models, but ultimately concludes that the fundamental assumption of being able to expand ordinary wavefunctions into a linear combination of eigenfunctions is more important. The square root of the delta function is seen as a better representation of the position eigenstate, but it is not as widely used. The conversation also touches on the idea of enlarging the function space to
Jano L.
75
Hi everybody,
it is usually said that the wavefunction of the localized particle at position [tex]x_0[/tex] is
[tex]
\psi_{x_0} = \delta (x-x_0).
[/tex]
Is there some good reason for this? I mean, this function cannot be normalized, which means that [tex]|\psi_{x_0}|^2[/tex] cannot be interpreted as a probability density. There is also problem that we can not use it to calculate the expectation value of position operator:
[tex]
\langle \psi |x|\psi\rangle = \int \delta(x-x_0)x\delta(x-x_0) = ?
[/tex]
What if we tried to solve this problem by square-rooting the delta function? We would have
[tex]
\langle \psi |x|\psi\rangle = \int \sqrt{\delta(x-x_0)}x\sqrt{\delta(x-x_0)} = x_0
[/tex]
What do you think? Why do we use delta function, which does not follow the rules for calculating expectation values?
You are right that the square root of the delta function is a better representation of the position eigenstate.
But there is an even better formal way to deal with this stuff. Imagine that space is not a continuum, but a very dense lattice. You can take the lattice spacing as small as you wish, so it is a good picture of the continuum for all practical purposes. Now the position eigenstate is a Cronecker delta. It has a beautiful property that the square root of the Cronecker is equal to the Cronecker itself.
Alternativley, you may work directly in the continuum by working with approximate position eigenstates represented by Gaussians of a very small width. Their width can be taken as small as you wish.
Thank you for the reply. Discrete space is a good idea - we get rid off the formal mathematical problems with normalization and infinities, but it is quite a strong physical assumption. What is the lattice and its spacing? This would be not Lorentz invariant... Even then, if we wanted to calculate the scalar product of two functions on the lattice, we would go back to the continuum model and integrate continuous functions. Although interesting, I think discrete model would be great change.
Let's stick to the continuum model for a while - then, my favourite for the localized wavefunction would be sharp normalized Gaussian, as you suggested. Then it is easy to calculate everything in the framework of QM and no problem arises.
But in textbooks, there is never [tex]\sqrt{\delta(x-x_0)}[/tex], but often [tex]\delta(x-x_0)[/tex]. One of the arguments I heard is that delta is the eigenfunction of the position operator:
[tex]
x\delta(x-x_0) = x_0\delta(x-x_0),
[/tex]
which is true in the distribution sense. If we had continuous normalizable wavefunction psi, the scalar product
[tex]
\langle \delta_{x_0}|\psi \rangle
[/tex]
is defined, but
[tex]
\langle \delta_{x_0}|\delta_{x_0} \rangle
[/tex]
is not defined. In contrary, for the square root of delta function, we have
[tex]
\langle \sqrt{\delta_{x_0}}|\psi \rangle = 0
[/tex]
and
[tex]
\langle \sqrt{\delta_{x_0}}|\sqrt{\delta_{x_0}} \rangle = 1
[/tex]
which leads to the conclusion that [tex]\sqrt{\delta(x-x_0)}[/tex] would be orthogonal to all normalizable wavefunctions, but itself, and therefore it is impossible to expand an ordinary function in these square roots.
Which assumption is more fundamental: normalizability (and therefore probabilistic interpretation of psi), or the fact that one should be able to expand ordinary wavefunction into a linear combination of eigenfunctions?
Or, are there other arguments that support delta against the square root of it?
This is a good question. I would say the latter is more fundamental, but it depends on what exactly one wants to achieve. Anyway, with the latter approach there are no any problems in practice, because one never measures the particle position with perfect accuracy. In other words, position eigenstates are never descriptions of actual physical states.
What kind of an animal (Where does it live?) is [itex]\sqrt{\delta_{x_0}}[/itex] that it can satisfy both
[tex]
[/tex]
and
[tex]
[/tex]
If [itex]\sqrt{\delta_{x_0}}[/itex] is either a state in a Hilbert space, or even a generalized state (functional on a Hilbert space), then the first condition (if true for all relevant [itex]\psi[/itex]) gives that [itex]\sqrt{\delta_{x_0}} = 0[/itex].
I was thinking about some sharp peak function like square root of normalized gaussian:
[tex]
\psi_{x_0}(x) = \frac{1}{\sigma^{1/2}(2\pi)^{1/4} } e^{-\frac{(x-x_0)^2}{4\sigma^2}}.
[/tex]
This function has unity norm but its scalar product with well behaved function goes to 0 as [tex]\sigma[/tex] goes to zero. In the limit [tex]\sigma \rightarrow 0[/tex] it is maybe not an ordinary function from the usual function spaces, but this was the case also with [tex]\delta[/tex]. Can we define this limit as the proper mathematical object?
[tex]
[/tex]
Yes, the zero distribution.
Consider dimensionally:
A delta function of x has dimensions of [L-1]. For correct normalisation, we require the spatial wavefunction to have dimension [L-1/2], suggesting that the square root is correct.
The problem you have with the delta function is due to the fact that you want to stay inside L². As soon as you allow for the closure of L² the problem disappears. Of course the wave function is no longer normalizable, but the formalism is still well definied.
Of course you can either deal with lattices, Gaussians etc. or you can try to enlarge L² appropriately.
Btw.: you have the same problem with plane wave states which are delta functions in momentum space.
[tex]
[/tex]
and
[tex]
[/tex]
Both these properties are pretty natural. The latter one tells that probability of a particle localized at [tex]x_0 [/tex] to be found at point [tex]x_0 [/tex] is equal to 1, which is a tautology.
The former property means that the probability of a particle with a (continuous) wave function [tex] \psi [/tex] to be found exactly at point [tex]x_0 [/tex] is zero. This is also true, because the "volume of the point'' [tex]x_0[/tex] is practically zero, and the chance of finding the particle there is negligible. However is we were able to sup up all these negligible chances over "all points in the space" we would get the total probability of 1.
When we use delta functions (instead of square roots of delta functions) for localized states, we are talking about "probability densities" at the point. These densities are generally non-zero and they can be integrated (instead of being summed over all points in space) to get the total probability of 1.
Eugene.
Actually... I don't think I've ever used either delta functions or square roots of delta functions directly.
I've only ever said: let's say we have a wave function |x> so that [tex]\hat x|x> = x|x>[/tex] and [tex]<x'|x> = \delta(x-x')[/tex]
We can also take this as a limit of a "Gaussian" wave packet: [tex]\Psi(x) = \lim_{a \rightarrow 0} \frac{1}{\sqrt{\sqrt{\pi}a}}e^{-\frac{x^2}{2a^2}}[/tex]
And this is exactly the square root of a delta function! The "Gaussian" wave packet is called such because [tex]|\Psi|^2[/tex] is a Gaussian, not [tex]\Psi[/tex]
So the way I was taught does in fact use a [tex]\sqrt{\delta}[/tex]
In one of my Quantum classes, we used a delta function potential well and talked about the solutions. To me this seemed strange because we ended up with only a single bound state that's not localized in the well (see http://en.wikipedia.org/wiki/Delta_potential). So it occurred to me a few days ago that we'd have to use [tex]\sqrt{\delta}[/tex] potential to get a bound state that's localized in the well. But I don't know what limit physically creates a square root of delta potential.
1. What is the wavefunction of the localized particle?
The wavefunction of a localized particle is a mathematical function that describes the probability amplitude for the particle to be found at a certain position in space at a given time. It is a fundamental concept in quantum mechanics.
2. How is the wavefunction of a localized particle different from a wavefunction of a delocalized particle?
A wavefunction of a localized particle is a function that is sharply peaked at a specific position in space, indicating a high probability of finding the particle at that position. In contrast, a wavefunction of a delocalized particle is spread out over a larger region, indicating a lower probability of finding the particle at any specific position.
3. Can the wavefunction of a localized particle change over time?
Yes, the wavefunction of a localized particle can change over time according to the Schrödinger equation, which describes how the wavefunction evolves in time. This is known as wavefunction collapse, and it occurs when the particle is measured or interacts with its environment.
4. How is the wavefunction of a localized particle related to the position and momentum of the particle?
The wavefunction of a localized particle contains information about the position and momentum of the particle. The position of the particle can be determined by taking the square of the wavefunction, while the momentum can be determined by taking the Fourier transform of the wavefunction. This relationship is known as the uncertainty principle.
5. What is the significance of the square of the wavefunction in quantum mechanics?
The square of the wavefunction represents the probability density of finding the particle at a certain position in space. In quantum mechanics, the wavefunction is used to calculate the probabilities of different outcomes in experiments, making it a crucial concept in understanding the behavior of particles at the quantum level.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
