Lower Frequencies pass through materials easier?
In summary, the lower frequency sound waves pass through materials easily because they are less attenuated.
richnfg
46
This is a question that has been bugging me for quite and long time and I have been searching on the Internet, but having no luck.
So, why does lower frequency sound pass through materials much easier then higher?
Thanks, Rich
I am not sure that 'easier' is the correct idea. Low frequency waves attentuate differently than high frequency waves. The are properties of the material such as bulk modulus and density, and structural properties like porosity and crystal structure which affect dispersion of sound. And then there is the geometric effects such as wall thickness in a pipe, which might match a wavelength of the sound.
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/souspe2.html
http://hyperphysics.phy-astr.gsu.edu/hbase/sound/sprop.html#c1
One needs the relationship between dispersion/attenuation and frequency.
Ok, so say you had 2 identical materials
you pass both a high and low frequncy sound through it, yet the lower passes through easier...thats what I meant to ask.
Probabaly didnt make it clear enough :P
anyone please?
Longer waves tend to be canceled out over longer distances where as shorter waves are more likely to be canceled out at shorter distances than longer waves.
what do you mean by canceled out?
as frequency is about how fast the atoms etc. vibrate? and amplitude the size of the vibration?
can you explain please! :)
Two waves of identical wavelength and opposite amplitude and direction will level each other.
Yes, but more specifically, its equal to the speed of the sound wave divided by it's wavelength. For sound, the wavelength is the distance between compressed regions of a longitudinal wave.
Amplitude of sound is specified in terms of either pressure (Pa) or decibels (dB), not size.
yeah, i know all that
but that doesn't explain why they cancel out :confused:
What frequencies (Hz or kHz range) or wavelengths are you using, and what is the dimension of the solid through which the sound is propagated?
How are you determining that one frequency propagates more easily - or do you mean one is less attenuated, i.e. more of the sound energy propagate through?
i am using frequencies of 1000Hz and 3500Hz and some cardboard around 2mm thick
by using an oscilloscope to see the amount that comes and reaches a microphone...the 1000Hz gives much bigger results showing more lower frequencies get through.
bump please
sorry, I know I am annoying
I just need the answer so bad
It might seem daft but is the resonant frequency of the cardboard the issue here ??
Astronuc has really put forth your answer.
for high frequencies the wavelength is shorter and the fibers or whatever stuff that is in your material are about the same size (or bigger) than the wavelength and will reflect the waves inside the material in random directions and your unified wavefront will be dispersed.
for low frequencies the wavelength is longer and the fibers or whatever stuff that is in your material will tend to simply be the medium for the acoustic wavefront and will just conduct it further.
I haven't done any research,nor do i have much knowledge on the propagation of sound waves, but i have an idea which i would like very much to be verified.
I take it that when you say 'by using an oscilloscope to see the amount that comes and reaches a microphone' you mean the amplitude of the resulting wave after passing through the cardboard
The max velocity of an oscillating particle is given by:
max velocity = (amplitude) x (angular frequency)^2
where angular frequency is directly proportional to frequency.
This implies that the max velocity of the atoms/molecules transmitting the sound waves is higher with a higher frequency.
since the root mean square of the velocity of the molecules is its thermodynamic temperature, it means that when a sound wave passes through, locally, the mean temperature is higher than the surrounding areas, resulting in a net energy transfer to its surroundings and energy loss for the sound wave.
the maximum potential of a particle in simple harmonic motion is directly related to the maximum displacement of the particle from its mean postion (in this case, the amplitude) so supposing that there is little deviation for the frequency, the loss of energy of the wave would result in a smaller amplitude for the sound wave.
can anyone with sufficient knowledge help me find a mistake in my reasoning? thanks.
Sound Travels through air / gas, liquid, even solid materials. Radio frequencies choose the medium which allows them to travel at the speed of light, elctro-magnetic waves. Earthquakes travel in waves (energy propagation).
Learn about how HF travels through the ionosphere. Its all about the wave length, medium of transportation and what it comes into contact with. Subs use ULF or ELF to go through water (electromagnetic) because there wave length allows them to penetrate through the water, and even deeper, unfortunately there antennas are gigantanormously long.
1. How do lower frequencies pass through materials easier?
Lower frequencies have longer wavelengths compared to higher frequencies. This allows them to pass through materials easier because they are less likely to be absorbed or scattered by the atoms or molecules in the material.
2. What types of materials do lower frequencies pass through easier?
Lower frequencies tend to pass through materials that are less dense and have larger spaces between atoms or molecules. These materials include air, water, and some types of gases.
3. Can lower frequencies pass through all types of materials?
No, lower frequencies cannot pass through all types of materials. Materials with higher density and smaller spaces between atoms or molecules, such as metals and thick solids, are more likely to block or reflect lower frequencies.
4. How does the thickness of a material affect the passage of lower frequencies?
The thickness of a material can affect the passage of lower frequencies by either increasing or decreasing the amount of energy that passes through. Thicker materials may absorb or reflect more of the lower frequency energy, while thinner materials may allow more energy to pass through.
5. Are there any practical applications for understanding how lower frequencies pass through materials?
Yes, understanding how lower frequencies pass through materials is important for various practical applications. For example, it is used in medical imaging techniques such as ultrasound, where lower frequencies are able to pass through body tissues to create images. It is also used in communication systems, such as radio and television, where lower frequencies are able to travel long distances through the atmosphere.
  • Other Physics Topics
