Average value of a double integral over a region
In summary, the average value of the function f(x,y) = e^(x+y) over the triangle with vertices (0,0), (0,1), and (1,0) is 2. The area of the triangle is 1/2 and the double integral of f(x,y) over the triangle is 1. Therefore, the average value is 1/2 divided by 1, which equals 2.
jonroberts74
189
f(x,y) = ##e^{x+y}## D is the triangle vertices (0,0), (0,1) , (1,0)
##f(x,y)_{avg}=\frac{\iint_D f(x,y) dA}{\iint_D dA}##
##\iint_D dA \Rightarrow \int_{0}^{1}\int_{0}^{-y+1} dxdy = \frac{1}{2}##
##\iint_D f(x,y) dA \Rightarrow \int_{0}^{1}\int_{0}^{-y+1} e^{x+y}dxdy ##
##\int_{0}^{1} e - e^y dy = 1##
##f(x,y)_{avg} = \frac{1}{1/2} = 2##
this doesn't seem correct.
nvm, was thinking about it incorrectly
Or: the area of a triangle is (1/2)(height)(base)= (1/2)(1)(1)= 1/2.
And this you can write as
[tex]\int_0^1 e^x\left(\int_0^{1- x}e^y dy\right)dx[/tex]
[tex]= \int_0^1 e^x\left[e^y\right]_0^{1- x}dx= \int_0^1 e^x\left[e^{1- x}- 1\right]dx[/tex]
[tex]=\int_0^1 e- e^x dx= \left[ex- e^x\right]_0^1= (e- e)- (0- 1)= 1[/tex]
Yes, it is correct.
Related to Average value of a double integral over a region
What does the average value of a double integral over a region represent?
The average value of a double integral over a region represents the average height or value of a function over a given region. It can also be thought of as the center of mass of a 2D object represented by the function.
How is the average value of a double integral over a region calculated?
The average value of a double integral over a region is calculated by dividing the double integral of the function over the region by the area of the region. Mathematically, it can be represented as: 1/A * ∬f(x,y) dA, where A is the area of the region.
What is the significance of the average value of a double integral over a region in real-world applications?
The average value of a double integral over a region has many real-world applications, such as calculating the average temperature of a region, the average population density, or the average force exerted on an object over a given area.
Can the average value of a double integral over a region be negative?
Yes, the average value of a double integral over a region can be negative. This can occur if the function being integrated has negative values over certain parts of the region, resulting in a negative average value.
What is the relationship between the average value of a double integral over a region and the mean value theorem for double integrals?
The mean value theorem for double integrals states that there exists a point within the region where the value of the function is equal to the average value of the function over the region. In other words, the average value of a double integral over a region is the same as the value of the function at a specific point within the region.
