Difference between Jordan normal form and diagonalising
BFeGhpY2FsIG1hdHJpeCBpbiBKb3JkYW4gbm9ybWFsIGZvcm0gYW5kIGRpYWdub3NhbGlhbGl6aW5nIGEgbWFyaW5lIGluIEpvcnRhbiBub3JtYWwgZm9ybSwgc3VjaCBBIHBpc3MgaW5kaXZpZHVhbCwgYXV0aGVudGljYWwgZm9ybSBvbiB0aGUgc2NhbGFyIGZpZWxkIG9mIGNvbXBsZXggbn
Ted123
446
What is the difference between putting a matrix in Jordan normal form and diagonalising a matrix?
Isn't a diagonal matrix in Jordan normal form?
i.e what is the difference between the questions:
Find matrices [itex]J[/itex] and [itex]P[/itex] where [itex]J[/itex] is in Jordan normal form and [itex]P[/itex] is invertible, such that [itex]A=PJP^{-1}[/itex]
Find matrices [itex]D[/itex] and [itex]P[/itex] where [itex]D[/itex] is diagonal and [itex]P[/itex] is invertible, such that [itex]A=PDP^{-1}[/itex]
Not every matrix is diagonalizable, but every matrix has a Jordan form (at least, if we work over the scalar field of complex numbers).
RGV
1. What is the difference between Jordan normal form and diagonalizing a matrix?
Jordan normal form is a special type of matrix that represents a linear transformation in a way that makes its properties more apparent. Diagonalizing a matrix involves finding a specific type of similarity transformation that results in a diagonal matrix.
2. How do you determine if a matrix can be diagonalized or put into Jordan normal form?
A matrix can be diagonalized if it has n linearly independent eigenvectors, where n is the dimension of the matrix. A matrix can be put into Jordan normal form if it is not diagonalizable and has n generalized eigenvectors, where n is the dimension of the matrix.
3. What is the purpose of finding the Jordan normal form or diagonalizing a matrix?
Finding the Jordan normal form or diagonalizing a matrix can make it easier to understand and analyze the properties of a linear transformation. It can also simplify calculations and make it easier to solve certain problems involving the matrix.
4. Can a matrix have both a Jordan normal form and be diagonalizable?
No, a matrix can either have a Jordan normal form or be diagonalizable, but not both. If a matrix has n linearly independent eigenvectors, then it is diagonalizable and cannot have a Jordan normal form. If a matrix is not diagonalizable, then it can have a Jordan normal form.
5. How do you find the Jordan normal form or diagonalizing transformation for a matrix?
To find the Jordan normal form, you need to find the eigenvalues and eigenvectors of the matrix. To diagonalize a matrix, you need to find the eigenvalues and eigenvectors, and then use them to construct a similarity transformation matrix. The diagonalizing transformation is the inverse of this similarity transformation matrix.
  • Linear and Abstract Algebra
  • Beyond the Standard Models
