Complex-valued solutions to real-valued solutions
  • Thread starter NINHARDCOREFAN
In summary, Two eigen value solutions, r=-1+-2i, were given for a problem along with their corresponding eigen vectors. The goal is to convert these complex solutions to real-valued solutions. The book used the eigen vector (-2i, 1) to come up with the solution x = c * e^(-t)( -2sin(2t), cos(2t) ) + d * e^(-t)( 2cos(2t), sin(2t) ), where c and d are constants. It is known that the real value of r=1+-2i should be e^(-t)sin(2t) + e^(-t)cos(2t), but it
NINHARDCOREFAN
118
I'm going crazy trying to figure out how to do this. Here are two eigen value solutions: r=-1+-2i to a problem. And the two eigen vectors are (-2i, 1) and (2i, 1). How do I covert this to a real-valued solution? The book used (-2i, 1) to come up with the solution x = c * e^(-t)( -2sin(2t), cos(2t) ) + d * e^(-t)( 2cos(2t), sin(2t) )
I know that real value of r=1+-2i should be e^(-t)sin(2t) + e^(-t)cos(2t) but I don't how they came up with their answer using this fact.
[tex]e^{ix}= cos(x)+i sin(x)[/tex]. Does that help?
1. What is the difference between complex-valued solutions and real-valued solutions?
The main difference between complex-valued solutions and real-valued solutions is that complex-valued solutions involve the use of complex numbers, which have both a real and imaginary component, while real-valued solutions only involve real numbers. Complex-valued solutions are often used in math and science to solve problems that cannot be solved with real numbers alone.
2. Why are complex-valued solutions necessary for certain problems?
Complex-valued solutions are necessary for certain problems because they allow for a more complete and accurate representation of the problem. Some problems, such as those involving waves or oscillations, cannot be fully described using only real numbers. Complex numbers provide a way to represent both the magnitude and phase of these types of phenomena.
3. How do complex-valued solutions relate to real-world applications?
Complex-valued solutions have many real-world applications, particularly in fields such as engineering, physics, and economics. They are used to model and analyze systems that involve oscillations, such as electrical circuits, mechanical systems, and financial markets. Complex-valued solutions also play a key role in signal processing and communication systems.
4. Can complex-valued solutions have real-valued solutions?
Yes, it is possible for complex-valued solutions to have real-valued solutions. In fact, many complex-valued equations have both real and complex solutions. This is because the solutions to these equations can involve both real and imaginary numbers, depending on the specific values of the variables involved.
5. How are complex-valued solutions related to the imaginary unit?
The imaginary unit, denoted by the letter i, is a fundamental part of complex-valued solutions. It is defined as the square root of -1, and allows us to represent the imaginary component of a complex number. In complex-valued solutions, the imaginary unit is often used to represent the phase or angular component of a waveform or oscillation.
