Help in steps on derivation of potential involve moving point charge.
Therefore, we can conclude that the expression in (2) is obtained by using the Pythagorean theorem. In summary, the conversation discusses finding the potentials of a point charge moving with constant velocity and the relevant equations for solving this problem. The solution from the book is provided, and the steps for obtaining the expression in (2) are explained using the Pythagorean theorem.
yungman
5,718
241
I mainly have problem is in the final step of the derivation, but I am going to list the steps leading to that:
The question is: Find the potentials of a point charge moving with constant velocity.
Relevant equation:
[tex]\vec w(t) = \;\hbox { is position of q at time t.}[/tex]
[tex]| \vec r - \vec w (t_r) |=c(t-t_r) \;\hbox { and }\; \eta =\vec r - \vec w(t_r)[/tex]
[tex]V_{(\vec r, t)} = \frac 1 {4\pi \epsilon _0} \frac {qc}{(\eta c -\vec {\eta} \cdot \vec v)} \;\hbox { and }\; \vec A_{(\vec r,t)} = \frac {\vec v}{c^2} V_{(\vec r, t)} [/tex]
Below is the solution from the book:
Let the particle passes through the origin at t=0 so that [tex]\vec w(t) = \vec v t[/tex]
[tex]\vec w(t_r)=\vec vt_r \Rightarrow \; |\vec r -\vec v_t_r|=c(t-t_r) \Rightarrow \; t_r=t\;^+_-\frac r c [/tex]
I skip a few step above to arrive to the solution of the retarded time tr.
[tex]\eta = |\vec r - \vec v t_r| \;\hbox { and } \hat { \eta} =\frac {\vec r -\vec v t_r}{c(t-t_r)} [/tex]
[tex]\Rightarrow \; \eta \left (1-\hat {\eta} \cdot \frac{\vec v(t_r)}{c}\right ) = \frac 1 c [(c^2t -\vec r \cdot \vec v)-(c^2-v^2)t_r] [/tex] (1)
[tex]\Rightarrow \; \eta \left (1-\hat {\eta} \cdot \frac{\vec v(t_r)}{c}\right ) = \frac 1 c \sqrt {(c^2t-\vec r \cdot \vec v)^2 + (c^2-v^2)(r^2 – c^2 t^2)}[/tex] (2)
I don’t get how to get from (1) to (2).
I tried squaring (1) and take the square root. But I don't know how to deal with the tr=t-(+/-)(v/c).
Can someone please explain how to get from (1) to (2)? The expression in (2) is obtained by using the Pythagorean theorem. The first term in the parentheses is the hypotenuse and the second term is the sum of squares of the other two sides. Note that we have t_r = t +/- (r/c). Therefore, we can expand the expression in (1) as follows: \eta \left (1-\hat {\eta} \cdot \frac{\vec v(t_r)}{c}\right ) = \frac 1 c [(c^2t -\vec r \cdot \vec v)-(c^2-v^2)(t + r/c)]= \frac 1 c [(c^2t -\vec r \cdot \vec v)-(c^2-v^2)t + (c^2-v^2)r/c]Now, we can use the Pythagorean theorem to obtain the expression in (2):\eta \left (1-\hat {\eta} \cdot \frac{\vec v(t_r)}{c}\right ) = \frac 1 c \sqrt {(c^2t-\vec r \cdot \vec v)^2 + (c^2-v^2)^2[t^2 + (r/c)^2]}
Related to Help in steps on derivation of potential involve moving point charge.
1. What is potential energy?
Potential energy is a measure of the energy an object has due to its position or configuration in a given system.
2. How is potential energy related to a moving point charge?
In the context of electromagnetism, potential energy is related to a moving point charge through the electric potential, which is a measure of the potential energy per unit charge at a given point in space.
3. What is the formula for calculating electric potential?
The formula for calculating electric potential is V = kQ/r, where V is the electric potential, k is the Coulomb constant, Q is the magnitude of the charge, and r is the distance from the charge to the point at which the potential is being calculated.
4. What is the process for deriving the potential due to a moving point charge?
The process for deriving the potential due to a moving point charge involves using the formula for electric potential and plugging in the values for the charge, distance, and Coulomb constant. Then, the resulting equation can be simplified and manipulated to solve for the electric potential at a given point.
5. What are some real-world applications of potential energy from moving point charges?
Potential energy from moving point charges has various applications in modern technology, such as in the design of electric circuits and the functioning of electronic devices. It is also crucial in understanding and predicting the behavior of particles in particle accelerators and in fields such as plasma physics and astrophysics.
