Hard time grasping the concept of the Geodesic
In summary, a Geodesic is the shortest possible path between two points on a curved surface and is equivalent to a straight line on a flat surface. Understanding this concept can be challenging because it goes against our everyday experience and involves complex mathematical equations. It is also a fundamental concept in Einstein's theory of relativity, describing the path that objects follow in the presence of gravity. The Geodesic has practical applications in navigation, robotics, and physics, and to better understand it, one can explore visual representations, study real-life examples, and have a basic understanding of geometry and calculus.
Philosophaie
462
Have a hard time grasping the concept of the Geodesic. If you are given a velocity and position of say a small astroid entering the gravitational field of the Earth. How do you find the trajectory or path it takes as it falls to Earth? Not afraid of tensors and advanced calculus.
You find the trajectory using Newton's law of gravitation.
I am trying to do this by sort of projectile motion but at greater distances from the Earth g varies by a factor of:
g = GM/(2r^2) making that calculation difficult. Any suggestions?
Related to Hard time grasping the concept of the Geodesic
What is a Geodesic?
A Geodesic is the shortest possible path between two points on a curved surface, such as a planet or a sphere. It is equivalent to a straight line on a flat surface.
Why is it difficult to grasp the concept of a Geodesic?
Understanding the concept of a Geodesic can be challenging because it goes against our everyday experience of straight lines being the shortest distance between two points. Additionally, the concept involves understanding complex mathematical equations and concepts such as curvature and geodesic curvature.
How is the Geodesic related to Einstein's theory of relativity?
The Geodesic is a fundamental concept in Einstein's theory of relativity. It describes the path that objects with mass naturally follow in the presence of gravity. In this theory, gravity is seen as the curvature of space and time, and the Geodesic is the path that objects follow on this curved space.
Can the Geodesic be applied to real-life situations?
Yes, the concept of the Geodesic has many practical applications in various fields such as navigation, robotics, and physics. For example, it is used in GPS systems to calculate the shortest path between two points on Earth's curved surface.
How can I better understand the concept of the Geodesic?
To understand the Geodesic better, it is helpful to have a basic understanding of geometry and calculus. You can also explore visual representations of the concept, such as using a globe or a curved surface to visualize the shortest paths between points. Additionally, studying real-life examples and applications of the Geodesic can also aid in understanding the concept.
  • Beyond the Standard Models
