In a railgun the lorentz force causes an object to be propelled
In summary, the use of non-magnetic metals such as aluminium is possible in railguns due to their ability to conduct electricity. The magnetic field is produced by the current in the rails, not by a magnetic material. Additionally, using a lighter metal like aluminium allows for faster acceleration of the projectile. As for using maglev technology, it would not be practical due to the need for a long vacuum tube and lack of friction for propulsion.
Bugmenot
In a railgun the lorentz force causes an object to be propelled in a direction because of an electromagnetic force caused by running a current through the "rails". How come you can use aluminium or another such non-magnetic metal as both rails and armature? Surely only a magentic metal would work?
You are interested in the ability of the metal to conduct electricity. The magnetic field is due to the current in the rail and projectile/armature. The design does not allow for the use of high permeability core material since there is no core.
AM
First of all, Al is cheap/inexpensive.
The effect is I x B, and B is induced by the currents in the rails, so a magnetic material is not necessary.
Al is relatively low density (sg ~2.7) as compared to steel (sg ~ 8.0), so for the same size, the Al would have much less mass, and consequently for a given force, it would accelerate faster.
I have seen railguns with copper rails which were used to fire steel projectiles - up to several km/s - for a relatively short gun.
So, in english, what your saying is it doesn't have to be ferromagnetic to get a magnetic field. Thanks
The magnetic field is produced by the current in the aluminum wire and NOT by a magnetic moment in a permanent magnet. Therefore, conductivity of the conductor is what is important, an Al is a very good conductor, and it is cheap.
Why can't they use maglev to fire projectiles?
No contact, no friction!
Probably because you would have to have a very long vacuum tube from your device to your target for it to make any significant difference.
1. What is a railgun?
A railgun is a type of electromagnetic launcher that uses a powerful electric current to propel an object at extremely high speeds. It works on the principle of the Lorentz force, which is the force exerted on a charged particle moving through an electric and magnetic field.
2. How does the Lorentz force work in a railgun?
The Lorentz force is the result of the interaction between the electric and magnetic fields generated by the railgun. As the electric current passes through the rails, it creates a strong magnetic field. This magnetic field interacts with the electric field created between the rails and the projectile, causing a force that propels the object forward.
3. What materials are used in a railgun?
The rails of a railgun are typically made of conductive materials such as copper, aluminum, or tungsten. The projectile is usually made of a conductive material, such as aluminum or a mixture of aluminum and copper, to allow for the passage of the electric current through it.
4. What are the advantages of using a railgun?
Railguns have several advantages over traditional firearms, including higher velocities, longer ranges, and more accurate trajectories. They also do not require chemical propellants, making them more environmentally friendly and reducing the risk of explosions.
5. What are some potential applications of railguns?
Railguns have potential applications in military and defense systems, space exploration, and transportation. They could also be used to launch satellites into orbit and for launching spacecraft into deep space missions. In addition, railguns could be used for high-speed transportation, such as launching cargo or passengers at hypersonic speeds.
  • Electromagnetism
  • Electromagnetism
