Heat of reaction in constant pressure calorimeter (Chemistry)
In summary, a 30.0mL sample of 0.937M A and a 16.7mL sample of 0.904M B are mixed in a constant pressure calorimeter. The final temperature of the reaction mixture is 21.7 degrees Celsius. The calculation involves finding the limiting reagent, determining the heat transferred (q), and solving for the final temperature using the heat equation. The reaction is exothermic, as the temperature goes up. However, the given attempt at a solution appears to be incorrect, and the correct final temperature should be 21.7 degrees Celsius.
mwamba
A 30.0mL sample of 0.937M A is mixed with 16.7mL of 0.904M B in a constant pressure calorimeter. The thermochemical equation for this reaction is:
A(aq) + B(aq) --> C(aq) + D(aq); ΔH = 41.2kJ
Both solutions are at 24.9 degrees Celsius prior to mixing and reacting. What is the final temperature of the reaction mixture? The density of all solutions is 1.00 g/mL and the specific heat is 4.184 J/gC.
q = mcΔT where m is mass, c is specific heat and ΔT is the change in temperature.
q = (30mL + 16.7mL) * 1.00g/mL * 4.184 J/gC * (xC - 24.9C) where C stands for Celsius and x is the final temperature (what we want to find).
Finding limiting reagent:
?mL A = 16.7mL B * (1L/1000mL) * ((0.904mol B)/1L) * ((1mol A)/0.937)*1000mL
= 16.11mL A < 16.7mL B so B is the limiting reagent
Finding q:
41200J = 1mol B * qJ/0.0151
q = 622.12J
Substituting q into the original equation to find x:
622.12J = (30mL + 16.7mL) * 1.00g/mL * 4.184 J/gC * (xC - 24.9C)
x = 28.1 degrees Celsius
This is apparently wrong. The answer is supposed to be 21.7 degrees Celsius. Does anyone see where I went wrong?
Sign. Is the reaction exothermic (temperature goes up) or endothermic (temperature goes down)?
What is the heat of reaction in constant pressure calorimeter?
The heat of reaction in constant pressure calorimeter is the amount of heat released or absorbed during a chemical reaction that occurs at a constant pressure. It is measured in joules (J) or kilojoules (kJ).
How is the heat of reaction in constant pressure calorimeter measured?
The heat of reaction in constant pressure calorimeter is measured by using a calorimeter, which is a device designed to measure heat changes. The reactants are mixed inside the calorimeter and the temperature change is measured, which can then be used to calculate the heat of reaction.
What factors can affect the heat of reaction in constant pressure calorimeter?
The heat of reaction in constant pressure calorimeter can be affected by factors such as the nature of the reactants, the concentration of the reactants, the temperature, and any changes in pressure or volume during the reaction.
How does the heat of reaction in constant pressure calorimeter relate to enthalpy?
The heat of reaction in constant pressure calorimeter is directly related to the change in enthalpy (ΔH) of the reaction. Enthalpy is a measure of the heat energy of a system at constant pressure, so the heat of reaction can be used to calculate the change in enthalpy.
Can the heat of reaction in constant pressure calorimeter be negative?
Yes, the heat of reaction in constant pressure calorimeter can be negative if the reaction is exothermic, meaning it releases heat. This indicates that the products of the reaction have a lower enthalpy than the reactants. A positive heat of reaction would indicate an endothermic reaction, where heat is absorbed.
