How can one measure the surface charge for a particle
In summary, the conversation discusses the measurement of surface charge of alginate beads with a diameter of 400μm. While most people use a zetasizer for this, it may not be suitable for larger particles. Alternative methods such as using a known field or measuring electrophoretic mobility are suggested, but determining zeta potential may be difficult due to varying particle surroundings. Checking with the manufacturer specifications for zetasizers that can handle larger sizes is also recommended.
GGdog0818
Here's the thing. I want to measure the surface charge of the alginate beads synthesized in our lab. It's about 400μm in diameter. I think most people uses zetasizer to examine the zeta-potential of small particles. But I think 400μm is probably too large for this kind of equipment to measure it.
So, are there any other kinds methods to determine the surface charge density of this particle?
Thank you.
Levitating them a known field? Accelerating them in a known field?
Put a bunch of them in an enclosed volume and measure the force needed to change volume.
Drop them at a known rate onto a conducting plate grounded through a sensitive galvenometer?
Drop them on the plate of an electrometer?
But the zetasizers are reported to handle sizes up to a few millimeters - have you checked with the manufacturer specifications?
Likes 1 person
You can easily measure electrophoretic mobility yourself (zetasizers do that too), and from it try to determine zeta-potential. However, the second part is more tricky. Zeta potential strongly depends on the particle surrounding and in some cases it may turn out to be very difficult if not impossible to find an appropriate model relating zeta potential and mobility. If you need to compare two particle suspensions, electrophoretic mobility may be sufficient.
Likes 1 person
1. How can I measure the surface charge of a particle?
There are several methods for measuring the surface charge of a particle. One common method is using a zeta potential analyzer, which measures the electric potential at the surface of a particle. Another method is using a surface charge titration, where the surface charge is measured by monitoring the change in pH or conductivity of a solution as charged particles are added.
2. What is the significance of measuring the surface charge of a particle?
The surface charge of a particle can greatly impact its behavior and interactions with other particles or surfaces. This measurement can provide insight into the stability, reactivity, and surface properties of a particle, which can have implications in various fields such as pharmaceuticals, environmental science, and materials science.
3. Can the surface charge of a particle change over time?
Yes, the surface charge of a particle can change over time due to various factors such as changes in pH, temperature, or the presence of other charged molecules. It is important to consider the conditions under which the measurement is taken and how they may affect the surface charge of the particle.
4. Is it possible to measure the surface charge of a single particle?
Yes, it is possible to measure the surface charge of a single particle using advanced techniques such as atomic force microscopy or laser Doppler electrophoresis. These methods allow for precise measurements of individual particles, which can be useful in certain applications such as studying the surface charge of nanoparticles.
5. What are some challenges in accurately measuring the surface charge of a particle?
One challenge in measuring the surface charge of a particle is ensuring that the measurement is representative of the entire particle and not just a certain area. This can be addressed by using multiple measurement techniques or averaging multiple measurements. Additionally, the presence of impurities or other charged molecules in the solution can interfere with the measurement and may require careful sample preparation or purification.
  • Electromagnetism
  • Quantum Physics
  • Electromagnetism
