What is the significance of the first e+e- narrow resonance discovery?
  • Thread starter forceface
In summary, this discovery was important because it showed that resonances involving the heavier charm quarks can be produced at high energy. This is useful information because it allows us to better understand the properties of the heavier charm quarks.
forceface
I was reading the paper about the discovery of the first e+e- narrow resonancehttp://prl.aps.org/abstract/PRL/v33/i23/p1406_1 and one question that came to my mind, which was why was this discovery important. In my naive understanding I would believe that this pair annihilation could happen anytime, where at low energies only photons would be produced, but at high energies more massive particles has the possibility of being produced and the latter is what is happening in the paper. In my mind this production of particles would be represented by something more steady than a sudden resonance. As the energy increases I would think the cross section for scattered hardons would increase a related rate.
The fact that the cross-section vs center-of-mass energy has peaks near the masses of unstable resonances can be understood fairly simply. We have a collection of processes ##e^+e^- \rightarrow X \rightarrow \mathrm{anything}##, where ##X## is one of the unstable particles that can be produced. The amplitude for a specific process looks like (we are assuming ##X## is a boson for simplicity)
$$ A = c_1 \frac{1}{p^2 - M^2 + i M\Gamma} c_2.$$
Here ##M## is the mass of the resonance ##X## and ##\Gamma## is its decay rate. The factor in the middle is the propagator for ##X## at 4-momentum ##p##. The factor ##c_2## describes the details of the interaction between ##X## and the ##e^+e^-## pair, while ##c_1## describes the interaction of ##X## with a specific collection of particles in the end state. The inclusive cross section would involve summing over all possible final states.
The cross-section depends on the modulus square of the amplitude and we can imagine expanding the result in terms of the ratio of the spatial components of the ##X## momentum with respect to the energy of the particle. For center-of-mass energy ##E## close to the mass of the resonance, most of the energy must go into producing the particle, so ##E\sim M## and the spatial momenta must be very small. If we neglect these corrections, we can write the corresponding probability in the form
$$ P \sim \frac{k}{(E^2 -M^2)^2 + (M\Gamma)^2},$$
which is known as the Breit-Wigner distribution. We use the variable ##k## to contain all of the precise details of the interactions involved in a specific process. You can verify that this function has the form of a curve with peak centered at ##E=M##. The width of the peak is related to the decay rate: the larger the decay rate, the broader the peak. Conversely, the smaller the decay rate (or more stable the particle is), the narrower the peak is.
We conclude from this that, whatever the detailed form of the cross-section for ##e^+e^- \rightarrow \mathrm{anything}##, we should find peaks around the masses of any resonances that are permitted to be produced at the given energy. At any given energy, there is a background corresponding to the events where we produce resonances with particles much lower than the c.o.m. energy, but whenever there is a stable enough resonance, there will be a well-defined peak in the spectrum that sticks out of the background.
To be totally convincing, one would have to do the hard work of actually computing the details of the amplitudes involved, or better yet, actually make the measurements and verify that the resonance peaks do in fact stand out from the background events. The Breit-Wigner distribution is an approximate description that actually turns out to be very useful to discuss certain properties of the observations.
So in other words this is the J/Psi particle.
That was the first observed resonance involving charm quarks, right.
1. What is the Narrow Resonance of e+e-?
The Narrow Resonance of e+e- is a phenomenon that occurs in particle physics experiments where there is a sudden increase in the number of electron-positron pairs produced. This is often seen as a peak in the data and is caused by the production of a new particle that quickly decays into an electron-positron pair.
2. How is the Narrow Resonance of e+e- detected?
The Narrow Resonance of e+e- is detected using particle detectors, such as the Large Hadron Collider (LHC) at CERN. These detectors are able to track and measure the energy and momentum of particles produced in collisions, allowing scientists to identify the presence of a new particle.
3. What is the significance of the Narrow Resonance of e+e-?
The Narrow Resonance of e+e- is significant because it can provide evidence for the existence of new particles that were previously unknown. These particles can help to improve our understanding of the fundamental laws of physics and the structure of matter.
4. How does the Narrow Resonance of e+e- relate to the Higgs boson?
The Higgs boson is a particle that was first predicted by the Standard Model of particle physics to explain how particles acquire mass. Its discovery in 2012 was confirmed by observing the Narrow Resonance of e+e- at the LHC, providing further evidence for the validity of the Standard Model.
5. Can the Narrow Resonance of e+e- be studied in other types of collisions?
Yes, the Narrow Resonance of e+e- can also be studied in collisions involving other particles, such as protons or heavy ions. These collisions can produce different types of particles and may provide additional insights into the nature of the new particles observed in the Narrow Resonance of e+e-.
  • High Energy, Nuclear, Particle Physics
  • Beyond the Standard Models
