Calculating the energy in projectiles from burst pressure vessels
In summary, the energy transferred to a projectile in the case of something bursting is estimated to be low, and the velocity of the projectile is estimated to be low.
Airou
Hi everyone,
I'm writing a safety case for pressure testing equipment using gaseous nitrogen (hydraulic pressure testing in this case is impractical) and I am trying to estimate the energy transferred to a projectile in the case of something bursting so I can sensibley mitigate against this eventuality.
I tried to estimate this by calculating the velocity acheived by the pressure acting on a projectile of given area and mass as it rides the expanding pressure wave and is accelerated by it. The figure I came up with seemed rather low in doing this.
Should I just assume that any projectile will travel at the speed of the burst/explosion (which I guess will be the speed of sound)? Or is there a more sensible way of working this out?
Many thanks.
Nah, you don't get supersonic chunks of steel from exploding pressure vessels. This is a very very tough one to figure out, as you never really know how the thing is going to fail. I use a similar method to you, don't know if it's right or not.
Can you give some more information on the test? Pressure, what's the vessel rated to, rough dimensions etc etc? What sort of figures have you been getting from your calculations?
This is the sort of thing of 'if in doubt, make it stout'. Ie you never ever get to the point where it does fail. Good suck it and see engineering.
Thanks for the reply.
The rigs I'm looking to test are made out of a whole load of components, not just one pressure vessel - refrigeration parts, flat plate heat exchangers, a compressor, pump, copper pipe etc. They are experimental rigs and are assembled by hand, so all the brazing is done by technicians. I know when most metal containers burst they just split, but I can't rule out that one technician might put in a sloppy braze after a night on the fizzy pop and something flies out if there is a failure.
I'm trying to change the relaxed attitude to health and safety in the workshop and would like to have all pressure testing that can't be done hydraulically to be done behind a lexan screen or something that can either absorb or deflect any likely projectiles. I want to include the calc for a safety case, and then use it to size the thickness of screen needed.
Currently the pressure test is done at 20 bar with an internal system volume in the assembly of approx 4 litres. For a 5mm diameter, 5 gram projectile I was calculating an ejection velocity of 0.14 m/s when assuming it was ejected from the surface of a spherical body of diameter 5cm. Intuitively this seemed very low, the air rifles I shot as a kid can't have held much pressure but were perfectly capable of putting a hole through 1/4" wooden boards. Looking at my calcs I wasn't sure how to tail off the pressure as the projectile is ejected, that is probably why it is on the low side, but I have no idea what is a likely figure - the pressure will be present for sometime as the gas filters through to the burst from the convoluted paths in the system, but it's not like there is a barrel to constrain the pressure and make the maths easy!
1. How do you calculate the energy in projectiles from burst pressure vessels?
To calculate the energy in projectiles from burst pressure vessels, you need to know the burst pressure of the vessel and the mass of the projectile. The formula for calculating energy is E=1/2 x m x v², where m is the mass of the projectile and v is the velocity at which it is launched. You can use the burst pressure to determine the velocity of the projectile at the moment of launch.
2. What is burst pressure and why is it important in calculating projectile energy?
Burst pressure is the maximum internal pressure that a vessel can withstand before rupturing. It is important in calculating projectile energy because it is the force that propels the projectile and determines its velocity. Without knowing the burst pressure, it is impossible to accurately calculate the energy of the projectile.
3. Are there any safety precautions that should be taken when conducting experiments with burst pressure vessels?
Yes, it is important to take safety precautions when working with burst pressure vessels. These include wearing protective gear, setting up a safe distance from the vessel, and using proper techniques when handling and launching the projectile. It is also important to follow all safety protocols and guidelines set by your institution or organization.
4. How can the energy in projectiles from burst pressure vessels be applied in real-world scenarios?
The energy in projectiles from burst pressure vessels can be applied in a variety of real-world scenarios, such as designing and testing military weapons, conducting research on the effects of high-velocity impacts, and developing safety measures for pressure vessels used in industries like aerospace and automotive. It can also be used in experiments and simulations to understand the behavior of projectiles under different conditions.
5. Are there any limitations to using burst pressure vessels to calculate the energy in projectiles?
Yes, there are some limitations to using burst pressure vessels to calculate projectile energy. These include variations in the burst pressure of different vessels, external factors like temperature and humidity that can affect the vessel's performance, and human error in conducting the experiments. It is important to consider these limitations and conduct multiple tests to ensure accurate results.
  • Mechanical Engineering
  • General Engineering
