Thermodynamics question - does power required mean same as power output?
In summary, to find the power required for an adiabatic compressor, one must first calculate the power output using the formula m Cp (T2 - T1). The power required refers to the input power needed to achieve the desired isentropic efficiency, which can be determined using the formula work required = power output/(isentropic efficiency). The problem involves a range of temperatures, so it is important to use the values of density, Cp, and other constants at the appropriate temperature, which in this case would be the final compressed temperature. Additionally, the relationship between temperature and volume during adiabatic compression must be considered in order to determine the work done. Finally, the density of the air being compressed should be used,
visharad
54
How to find power required for adiabatic compressor?
Problem - Air enters an adiabatic compressor at 20 C and 1bar. The volumetric flow rate of air is 1 m3/s and it exits at 200 C. Determine the power required if the isentropic efficiency of the compressor is 80%.
Density of water = 1000 kg/m^3
Mass flow rate m = 1 m^3/s * 1000 kg/m^3 = 1000 kg/s
I know that power output is calculated by
m Cp (T2 - T1)
But what is meant by power required? Is it same as power output or is it power input?
If it is power output, then we can calculate it using m Cp (T2 - T1)
If it is power input, then can we use work required = power output/(isentropic efficiency) ?
The problem involves a range of temperatures. I have to use the values of density, Cp and any other constants needed at what temperature? Initial? Final? Average?
I guess it means the power required to allow that 80% efficiency therefore it would be an input, if something is requiring power, it's awaiting an input.
m Cp (T2 - T1)
First find the power required to compress 1 m^3 of air every second. Hint: you have to determine the final compressed volume of that 1 m^3 of air. You are given its final temperature. What is the relationship between temperature and volume during an adiabatic compression? What is the work done?
Second, determine how much input power is required at 80% efficiency (ie only 80% of the input energy does work in compressing the air.
AM
Hint: The density of water (1000 kg/m^3) is not the same as the density of the air moving through the compressor.)
Power required and power output are two different concepts in thermodynamics. Power required refers to the amount of power needed to operate a system, while power output refers to the amount of power that is actually produced by the system.
In the context of an adiabatic compressor, power required would refer to the amount of power needed to drive the compressor and compress the air. This would include the power needed to overcome any frictional losses and work done on the air to compress it.
To find the power required for an adiabatic compressor, we can use the equation P = m*Cp*(T2-T1), where P is the power required, m is the mass flow rate, Cp is the specific heat capacity, and T2-T1 is the change in temperature of the air. In this problem, we are given the values for m, Cp, and T2-T1, so we can calculate the power required using this equation.
If we want to take into account the efficiency of the compressor, we can use the equation P = Pout/η, where Pout is the power output and η is the isentropic efficiency. In this case, the power output would be equal to m*Cp*(T2-T1), so we can substitute this into the equation to get P = (m*Cp*(T2-T1))/η.
As for the values of density and Cp, we can use the values at any temperature as long as they are consistent throughout the calculation. In this case, since the problem does not specify a specific temperature, we can use the values at the initial temperature of 20°C or the final temperature of 200°C. Both values should give us the same result for power required.
1. What is the definition of power in thermodynamics?
In thermodynamics, power is defined as the rate at which energy is transferred or converted. It is measured in units of watts (W) or joules per second (J/s).
2. How is power required different from power output in thermodynamics?
Power required refers to the amount of energy needed to perform a certain task, while power output refers to the amount of energy that is actually produced or delivered. In other words, power required is the input energy, while power output is the output energy.
3. Is power required always equal to power output in thermodynamics?
No, power required and power output are not always equal in thermodynamics. In fact, there is often a difference between the two due to factors such as inefficiencies in the conversion process, losses in energy, and external influences.
4. How is power related to work in thermodynamics?
Power and work are closely related in thermodynamics. Work is the transfer of energy from one system to another, and power is the rate at which this transfer occurs. In other words, power is the amount of work done per unit of time.
5. Can power be calculated using thermodynamic equations?
Yes, power can be calculated using thermodynamic equations such as the first and second laws of thermodynamics. These equations take into account factors such as temperature, heat, and work to determine the amount of power required or output by a system.
15K
