[Mathematica Help] An integration involving many vector variables
In summary, the conversation discusses the integration of a complex function with six terms, each of which is a complex conjugate. The function, F, is to be evaluated and visualized in Mathematica. The person has successfully done the one-dimensional case but is having trouble with the 2-D case. They are unsure about how to handle vector variables and complex numbers in integration. They attempt to use the function Integrate but get an error message. They then question the correctness of their approach and ask for guidance on how to solve such integrations involving vector variables and complex numbers.
elduderino
57
I have an expression which has six terms. I am posting one of the terms, in its basic form:
[tex]
f1= \int \frac{d\vec{k}}{( \xi [\vec{k}] + i d - \xi [\vec{k}-\vec{b}] ) ( \xi [\vec{k}] + i c + i d - \xi [\vec{k}-\vec{a} - \vec{b}]) }
[/tex]
Then there are f2, f3,f4..f6. They are all complex conjugates.
The six terms together constitute the expression [tex] F(\vec{a},\vec{b},c,d,\vec{k})[/tex]. I am to integrate and hence evaluate and visualize the function [tex] F(\vec{a},\vec{b},c,d,\vec{k})[/tex] in Mathematica. I was able to do the one-dimensional case correctly, where all the variables can be treated as scalars. However I am having trouble doing the 2-D case.
In fact, I am a little unsure about how the math works when vectors are involved, and also how to make mathematica evaluate this integration for me. Here is what I tried.
I declared
k={kx,ky} ... a={ax,ay} ... etc
The function [tex] F(\vec{a},\vec{b},c,d,\vec{k})[/tex] now becomes a list as:
[tex] F(\vec{a},\vec{b},c,d,\vec{k}) = \{ F(ax,bx,c,d,kx) , F(ay,by,c,d,ky) \} [/tex]
Now if I use: Integrate[F, k]
I should expect an output of the form {Expr1,Expr2}
However, I get an error... "Integrate::ilim: Invalid integration variable or limit(s) in {kx,ky}."
Can somebody explain what I am doing wrong here?
Even more fundamentally, I somehow doubt if this approach to carrying out the integration is correct. Can someone hint how such integrations involving vector variables and complexes (iotas) are solved?
If I define:
f[t_] := {t, Sqrt[t + 1], -Exp[t]}
and then compute
Integrate[f[t], t]
I get the expected result
{t^2/2, 2/3 (1 + t)^(3/2), -E^t}
So Mathematica can evaluate the integral of vector valued functions. Are you perhaps trying to integrate over a surface or a field where the function is not just vector valued but also takes vector arguments?
I would suggest approaching this problem by breaking it down into smaller, more manageable parts. First, it may be helpful to review the mathematical principles behind vector integration and complex conjugates. This will give you a better understanding of the problem and how to approach it.
Next, I would suggest consulting Mathematica's documentation or seeking help from a mathematician or experienced Mathematica user. They may be able to provide specific tips or functions to use for integrating expressions involving vector variables.
Another approach could be to simplify the expression by hand before attempting to integrate it in Mathematica. This may involve using properties of vector operations or simplifying the complex conjugates.
Overall, it is important to have a solid understanding of the problem and the tools available in Mathematica before attempting to integrate such complex expressions. It may also be helpful to break down the problem into smaller steps and test each step to ensure it is working correctly before moving on to the next step.
1. What is Mathematica and how is it used in scientific research?
Mathematica is a computational software program used for performing mathematical and statistical calculations, data analysis, and visualization. It is commonly used in scientific research to solve complex equations, simulate experiments, and analyze large datasets.
2. Can Mathematica handle integrations involving multiple vector variables?
Yes, Mathematica has built-in functions for handling integrations involving multiple vector variables. It can handle both definite and indefinite integrals, and also supports vector calculus operations such as gradient, divergence, and curl.
3. How does Mathematica handle vector variables in integrals?
In Mathematica, vector variables are represented using the Vector or Tensor data types. These variables can be used in integrals just like regular numerical or symbolic variables. Mathematica also has specific functions for handling vector integrals, such as Integrate and NIntegrate.
4. Are there any special considerations when using vector variables in integrals?
Yes, when using vector variables in integrals, it is important to specify the correct coordinate system and basis vectors. Mathematica provides a variety of built-in coordinate systems and basis vectors for common applications, but users can also define their own custom coordinate systems if needed.
5. Can Mathematica handle vector integrals in higher dimensions?
Yes, Mathematica can handle vector integrals in any number of dimensions. It also has specific functions for handling integrals in higher dimensions, such as Integrate and NIntegrate. Users can specify the number of dimensions in the integral function or use the Tensor data type to represent higher-dimensional vectors.
  • Electromagnetism
