Conservative forces and systems
In summary, according to the definition of conservative and non-conservative forces, gravity cannot be classified as a constraint force. The concept of constraint forces does not apply to gravity, as it continuously does work on particles in a system. However, in Newtonian mechanics, gravity is considered a conservative force due to the constant mechanical energy of the system. It is possible that the confusion arises from considering the kinetic and potential energy of the orbiting object, which would not take into account the work done by gravity on the particles.
Aniket1
62
I read in a book that if the constraint forces do work, the system is conservative, else it's nonconservative. In that case, consider a system of two bodies moving in an elliptical path under gravitational attraction. Since the gravitational force is continuously doing work on the particles, by the above definition, gravitation is a nonconservative force and the system is nonconservative. However, the mechanical energy of the system remains constant and in Newtonian mechanics, gravitation is classifed under conservative force. Can someone explain where am I going wrong.
Are you counting the kinetic and potential energy of the orbiting object?
Yes.
What book did you read this in?
Gravity is not a constraint force.
The term 'constraint force' is used to describe forces that essentially act to impose boundary conditions. An example is the reaction force of the ground on you, stopping you falling through it.
Generally these forces don't do work, since they don't act through any distance.
So the question of them being conservative or non-conservative is meaningless.
1. What is a conservative force?
A conservative force is a type of force in physics that satisfies the law of conservation of mechanical energy. This means that the total mechanical energy (kinetic energy + potential energy) of a system remains constant, and energy is neither created nor destroyed.
2. What are some examples of conservative forces?
Some examples of conservative forces include gravity, electrostatic force, and elastic force. These forces can be described by potential energy functions, and their work done on a system is independent of the path taken.
3. How does a conservative force affect the motion of an object?
A conservative force does not change the total mechanical energy of a system, but it can transform potential energy into kinetic energy and vice versa. As an object moves in a conservative force field, the work done by the force is equal to the change in potential energy, and the net work done is zero.
4. What is a conservative force field?
A conservative force field is a region in which a conservative force acts on objects. It is characterized by a potential energy function that describes the energy associated with the position of the object in the field.
5. How can you determine if a force is conservative or not?
A force is conservative if its work done on a closed path is zero. This can also be determined by checking if the force can be expressed as the gradient of a potential energy function. If a force is not conservative, it is considered a non-conservative or dissipative force, which means it can transform mechanical energy into other forms such as heat or sound.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Mechanics
