How Do You Convert Equations Into Vector and Parametric Forms?
In summary: Yes, the circle touches the origin, but it doesn't cross the origin.It also touches the x-axis and the y-axis.The circle crosses the x-axis at two points.And the circle crosses the y-axis at two points.
paperdoll
69
I have three questions regarding vectors in parametric/circle form. I understand that there is a starting point and a direction vector, but I just can't seem to get my head around this :confused:
1. Rewrite y=3x-1 in vector form.
2. Rewrite r=ti+(2t-1)j in parametric form
3. Where does the circle |r-(i+2j)|=root 5 cut the coordinate axes?
For 1. I got -j+t(2i+5j) but I'm dubious my answer since I tried it after watching a bunch of youtube videos regarding such questions.
For no. 2, I am really lost where to even start :S
For question 3, I know the radius is root 5, and the centre point is i+2j but not sure where to go from here...thanks if you can help ^^ I'm new here
Welcome to PF, paperdoll! :smile:
For 1: no your expression is not correct.
How did you get your expression? That would help me understand what I should explain.
For 2: the parametric form is r = p + t q.
You need to find what needs to be multiplied by t, and what is not multiplied by t.
For 3: Did you try to draw it?
For starters, what is the distance of the center of the circle to the origin?
Additional. In 1, x is NOT a constant. In 2, separate the vectors into x and y components.
You need to find what need to be multiplied by t, and what is not multiplied by t.
For 1, I substituted numbers into the expression y=3x-1. In this case, x=2, then y=5, because I read that you needed to find a vector parallel so then I got 2i+5j. and I somehow got -j in the beginning because I thought the starting point of the vector was "-1".
For 2, I have factorised the t out of it to get r=-j+t(i+2j)...not sure where to go from here.
For 3, I would say that the distance from the centre to the origin will be:
1^2+2^2=x^2 x=root 5
does this mean it touches at the origin then? since the original radius is root 5. I drew a picture of it, seems like it touches on the origin, once on the y-axis and once again on the x-axis. from that, I got it touches at x=2, y=0 and y=4, x=0...but this is from diagram, not from the equation :confused:
Thank you for replying to my post I like Serena :)
The vector equation for any line is of the form [itex]\vec{r}(t)= \vec{p}+ t \vec{v}[/itex] where [itex]\vec{p}[/itex] is the position vector of a point on the line and [itex]\vec{v}[/itex] is a vector in the direction of the line.
That is going the wrong way! The original equation said r= ti+ (2t-1)j.
So x= ? and y= ?
I would consider the "distance from the centre to the origin" as not particularly relevant.
You know that the center is at (1, 2) and the radius is [itex]\sqrt{5}[/itex], yes, that means that circle passes through the origin but there are two other points where the circle crosses the x and y axes. I presume you see, from the centre and origin information, that [itex](x- 1)^2+ (y- 2)^2= 5[/itex]
Where it crosses the x-axis y= 0 so [itex](0-1)^2+ (y- 2)^2= 5[/itex]. Solve for y.
Where it crosses the y-axis x= 0 so [itex](x- 1)^2+ (0- 2)^2= 5[/itex]. Solve for x.
You were right that a starting point of the line was "-1".
So your -j is right! :smile:
You also found another point on the line 2i+5j.
However, the vector you need is the vector from your starting point to this other point on the line.
So you need to subtract the one from the other.
Hmm, as far as I'm concerned that is the parametric form.
But HallsofIvy has a point.
Your teacher no doubt intended you to find an expression for x and an expression for y.
Sorry to set you on the wrong way here. :blushing:
So you need to gather everything that is multiplied by i. That is your x.
And you need to gather everything that is multiplied by j. That is your y.
Yes! :smile:
In my opinion, these things are best learned from first drawing what you are doing.
And as you can see you already have the solution.
I let you calculate the distance to the origin so you'd have an instant handle on the thing. ;)
Alternatively you can calculate them from the equation.
That will be what your teacher intended.
To do that you need to fill in x=0 (or r=yj) in your equation and solve it.
That will give you all intersections with the y-axis.
After that you need to fill in y=0 (or r=xi) in your equation and solve it again.
That will give you all intersections with the x-axis.
HallsofIvy said:
paperdoll said:
For 1, I substituted numbers into the expression y=3x-1. In this case, x=2, then y=5, because I read that you needed to find a vector parallel so then I got 2i+5j. and I somehow got -j in the beginning because I thought the starting point of the vector was "-1". [/itex]
The vector equation for any line is of the form [itex]\vec{r}(t)= \vec{p}+ t\vec{v}[/itex] where [itex]\vec{p}[/itex] is the position vector of a point on the line and [itex]\vec{v}[/itex] is a vector in the direction of the line. That is going the wrong way! The original equation said r= ti+ (2t-1)j.
So x= ? and y= ? I would consider the "distance from the centre to the origin" as not particularly relevant.
Oh thankyou, I understand No 3 now with the equation and the diagram together ^^
I'm not really sure what do you mean for the "position vector on a point" and "a vector in the direction of a line". Do I need to write the equation in terms of i and j? All the examples in my textbook are like this :confused:
For number 2, x=ti and y=2t-1 I think :)
As for number 2, you need to leave out "i" in your expression for x, but what you have is right! :smile:Here's a picture for number 1.
(I like pictures! :cool:)
http://www.netcomuk.co.uk/~jenolive/vecline.gif
I borrowed it from: http://www.netcomuk.co.uk/~jenolive/vect3.html
In this picture "a" is the position vector on a point, and b is the "direction vector" in the direction of the line.
To find "a" you can take any point, for instance the one you already had: -j.
To find a suitable "b", you can take any 2 points on the line and subtract them from each other.
Can you think of 2 points? And subtract them?
okey, so hmm two points {x=2, y=5} and {x=4, y=11} so I resulted in 2i+6j which can simplify to i+3j? I am a bit confused what do you mean by "subtracting points" because the diagram looks like the "b" value is not on the r line itself O__o
LOL at *I like pictures*, so do I.
Yep! That's it! :smile:
You have just learned vector subtraction!
When you subtract one point from the other, you get the vector that connects the 2 points.
"a" and "r" are vectors from the origin to a point on the line.
"b" is a vector from a point on the line to a point on the line.
So what's the final expression?
(Btw, you could also have used {x=0, y=-1}.)
final expression I got is -j+t(i+3j) :shy:
thank you so much for the help ^^ it helped so much!
You're welcome! :smile:
1. What is vector form?
Vector form represents a line or curve using a single vector equation, rather than multiple slope and intercept equations.
2. What is parametric form?
Parametric form represents a line or curve using multiple equations, where each variable is expressed in terms of a single parameter.
3. What are the benefits of using vector and parametric form?
Vector and parametric form allow for a more concise and efficient representation of lines and curves in space, making them easier to work with in mathematical equations and computer graphics.
4. How do you convert between vector and parametric form?
To convert from vector form to parametric form, you can solve for each variable in terms of a single parameter. To convert from parametric form to vector form, you can combine the equations into a single vector equation.
5. In what situations would you use vector and parametric form?
Vector and parametric form are often used in physics, engineering, and computer graphics to describe the motion of objects in space, as well as in calculus to represent curves in multiple dimensions.
  • Linear and Abstract Algebra
