The Milky Way from the Andromeda Galaxy: Edge-on, Spiral, or In-Between?
In summary, if an observer on the Andromeda galaxy looked back at us, they would see the Milky Way galaxy tilted at a slight angle, between edge-on and face on, but closer to edge on. This is because Andromeda is located within 15 degrees of the center of the Milky Way's band of stars. This can be seen in the map provided by the Harvard-Smithsonian Center for Astrophysics.
Fozzie
If an observer on the Andromeda galaxy looked back at us, how would the Milky Way galaxy look to him? Edge-on, spiral face on, or in between?
Astronomy news on Phys.org
It depends on whether the constellation Andromeda is in the Milkyway band of stars. As I recall, it is more or less. Therefore he would see us edge on (if that is true).
Yes. Look!
http://www.cfa.harvard.edu/afoe/And.html
This map shows the band of the Milkyway, and it also shows a dot where the Andr. galaxy is. It is not right exactly in the band, but rather close.
It is within 15 degrees of the center of the band. 15 degrees is a fairly small angle. So he would not see us exactly edge on, but with a slight tilt of 15 degrees.
Andromeda (m31) is about 20 degrees below the Galactic plane. So, I assume that, looking back along that line of sight , you'd see the MW as somewhere between edge-on and face on, but closer to edge on.
A bit like we see Andromeda then? Thanks!
I would like to clarify that the appearance of the Milky Way galaxy to an observer on the Andromeda galaxy would depend on their relative position and orientation. If the Andromeda galaxy is directly facing the Milky Way, then it would appear as a spiral galaxy to the observer. However, if the Andromeda galaxy is positioned at an angle to the Milky Way, then it may appear to be edge-on or in-between, depending on the specific angle and orientation.
Furthermore, the shape and appearance of galaxies can also be affected by various factors such as dust and gas clouds, which can obscure or distort the view. Therefore, it is difficult to accurately predict how the Milky Way would appear to an observer on the Andromeda galaxy without knowing their exact position and orientation.
Overall, the Milky Way can appear as a spiral, edge-on, or in-between galaxy to an observer on the Andromeda galaxy, depending on their relative positions and other environmental factors. Further studies and observations are needed to understand the exact appearance of our galaxy from the perspective of the Andromeda galaxy.
1. What is the Milky Way and Andromeda Galaxy?
The Milky Way and Andromeda Galaxy are two of the largest and most well-known galaxies in the universe. They are spiral-shaped collections of stars, gas, and dust that are held together by gravity.
2. How far away is the Andromeda Galaxy from the Milky Way?
The Andromeda Galaxy is approximately 2.5 million light years away from the Milky Way. This means that it takes light 2.5 million years to travel from one galaxy to the other.
3. Is the Milky Way edge-on, spiral, or in-between when viewed from the Andromeda Galaxy?
When viewed from the Andromeda Galaxy, the Milky Way appears to be in-between. This is because we are viewing it from a different angle than we would if we were inside the Milky Way.
4. How do scientists determine the shape of the Milky Way from the Andromeda Galaxy?
Scientists use a variety of methods to determine the shape of the Milky Way from the Andromeda Galaxy. This includes studying the distribution of stars and gas, analyzing the rotation of the Milky Way, and using computer simulations to model its structure.
5. Will the Milky Way and Andromeda Galaxy eventually collide?
Yes, the Milky Way and Andromeda Galaxy are on a collision course and are expected to collide in approximately 4 billion years. However, the collision is not expected to cause any major disruptions to either galaxy, as the distance between individual stars is so vast that they are unlikely to collide with each other.
  • Astronomy and Astrophysics
