The set of all continuous functions
In summary, the set of all continuous functions (c) has cardinality equal to the set of all integrable functions (I), which has cardinality at least c.
srfriggen
306
I suppose my question is, "does the set of all continuous functions comprise a continuum?"
How would one even start at trying to prove that? Any ideas or suggestions?
A continuum as in "a compact, connected metric space"??
And the continuous functions from where to where??
Mapping from the reals to the reals... And by continuum I mean it's cardinality, aleph 1.
You probably mean to say that the set of all continuous functions has cardinality the same as the reals?? Right? The reals do NOT in general have cardinality aleph 1!
So in general, you cannot prove that the continuous functions from the reals to the reals have cardinality aleph 1.
Anyway, you can prove that the cardinality of continuous function is the same as the reals.
I'll give you a hint. Consider the continuous functions [itex]\mathcal{C}(\mathbb{Z},\mathbb{R})[/itex] and [itex]\mathcal{C}(\mathbb{Q},\mathbb{R})[/itex].
Thanks guys... And yes I ahold have said 2^aleph naught (or just the cardinality of the reals. Tried to get too fancy).
Thanks for the link marhman
Thanks for the link mathman but I'm going to try working on it a bit before I view it.
Micromass, My highest level of math is "bridge to advanced mathematics" course, learning some set theory and how to read and write proofs, but it ended just before Real Analysis. Do u think that is enough background to attempt this proof? If so, any more hints before I hit the whiteboard? (actually pulled over in my car now on my way home!)
You just need one little fact: if [itex]f,g:\mathbb{R}\rightarrow \mathbb{R}[/itex] that coincide on [itex]\mathbb{Q}[/itex], then f=g. This is usually proven in a real analysis class, but you could try to prove this. This is the crucial fact to be able to tackle this thing.
Thanks!
hey micromass,
(first off I want to apologize for the lengthy response below. I'll understand if you feel I'm overstepping my forum bounds, just let me know.)
So I mapped out a strategy for the proof and worked it out do a decent degree, but eventually checked out the link mathman posted. Seemed my ideas were similar. I went back to the drawing board about just what a function is (as they teach you in HS), with inputs and outputs. I realized the inputs would have c as the cardinality and so would the outputs, so I started to try to used some sort of Squeeze Theorem type of logic... in mathmans link it was the cantor-schroeder-bernstein theorem.
So I outlined my proof pretty well I think, but I couldn't figure out where to use your theorem. So I eventually checked out mathman's link and to tell you the truth I still don't understand how that comes into play.
Perhaps you can elaborate, I don't expect you to explain an entire proof to me though.
But anyway, the answer is "c" as mathman and the link showed. So now I've been thinking and I have a different question for you... What would the cardinality be of the set of all integrable functions that map from the Reals to the Reals?
Here's what I've come up with so far (I've just been outlining approaches, nothing concrete):
"First, call the set of all integrable functions that map from the reals to the reals I.
From previous discussion we know that the cardinality of the set of all continuous functions mapping from the Reals to the Reals is c. Now every continuous function is integrable [can't remember where I learned that, I suppose I'll have to find it and insert that theorem here] but not every integrable function is continuous. Therefore, the set of all continuous functions is a proper subset of the set of all integrable functions, where both sets map from R to R.
By this we can determine that the cardinality of I is at least c."
Am I on the right path here?
Thank you kindly
srfriggen said:
hey micromass,
Well, it comes into play in the folowing sentence of mathman's link:
Since the rational points are dense, this determines the function.
What I said is equivalent with that sentence. Do you see why this sentence is true, or do I need to explain??
Some remarks:
1) You must be careful and state which kind of integrability your talking about. Is it Riemann integrablity? Lebesgue integrability?? The answers will (likely) depend on this.
2) You say that every continuous function is integrable. This holds true, but only if the domain of the function is a closed interval (or some easy modification). So any continuous function [itex]f:[a,b]\rightarrow \mathbb{R}[/itex] is integrable. On the other hand, an easy function like [itex]f:\mathbb{R}\rightarrow \mathbb{R}:x\rightarrow x[/itex] is not integrable.
3) I do like the approach you made that shows that the integrable functions have at least cardinality c. But it'll be somewhat harder to find an upper bound.
What comes to mind is "42". Seems I am looking for an answer without first knowing the question! (if you haven't read the hitchhikers guide to the universe do so now!)
okay, I'll look into it and really decide what type of integration I want to try to use. Thanks for the tip on the closed interval, it's been a while since calculus.
with regard to mathmans post and the "rationals being dense so that determines the function" I really don't understand that very well. If you can elaborate on how the upper bound was determined I'd greatly appreciate. (I specifically don't understand the phrase "so that determines the function")
The key to the upper bound is the function
[tex]\mathcal{C}(\mathbb{R},\mathbb{R})\rightarrow \mathbb{R}^\mathbb{Q}:f\rightarrow f\vert_\mathbb{Q}[/tex]
it suffices to show that this function is an injection (since [itex]\mathbb{R}^\mathbb{Q}[/itex] has cardinality c). For this, we must show that if [itex]f\vert_\mathbb{Q}=g\vert_\mathbb{Q}[/itex], then f=g. This holds since [itex]\mathbb{Q}[/itex] is countable.
Perhaps you can just help me with some of the terminology... I'm sorry but I simply don't understand what a lot of the symbols you used are. I've never encountered functions written with a set as a superscript or a subscript. Does the "C" mean cardinality? Also, I'm assuming "dense" is equivalent to "countable"
You mean [itex]f\vert_\mathbb{Q}[/itex]? That just means that we restrict the domain of f to [itex]\mathbb{Q}[/itex].
Yes, c is the cardinaility of the continuum.
No, saying that a set A is dense means that the closure of A is [itex]\mathbb{R}[/itex]. http://en.wikipedia.org/wiki/Dense_set
What about when you wrote R^Q?
(I never got into this stuff in my class. I suppose I will if I continue to Real Analysis?)
That's just the set of all functions [itex]\mathbb{Q}\rightarrow \mathbb{R}[/itex].
Yes, I'm sure you'll see it in real analysis. Or set theory of something of the like.
ok, thanks for your help and patience micromass. I really appreciate it! take it easy.
1. What is the set of all continuous functions?
The set of all continuous functions is a collection of functions that have a continuous graph, meaning there are no breaks or abrupt changes in the function's output. These functions are defined for all real numbers and have a smooth, unbroken curve when graphed.
2. Can all functions be classified as continuous or non-continuous?
No, not all functions can be classified as either continuous or non-continuous. There are some functions that may have points of discontinuity, such as a jump or hole in the graph, which would make them neither fully continuous nor fully non-continuous.
3. What is the importance of the set of all continuous functions in mathematics?
The set of all continuous functions is an important concept in mathematics as it helps us understand the behavior of functions and their graphs. It also plays a crucial role in many mathematical fields, including calculus, analysis, and topology.
4. Are there any real-world applications of continuous functions?
Yes, there are many real-world applications of continuous functions. For example, they are used in physics to model the motion of objects, in economics to represent demand and supply curves, and in engineering to design smooth and efficient systems.
5. How can we determine if a function is continuous?
A function can be determined as continuous if it satisfies the three conditions of continuity: 1) The function is defined at the point in question, 2) the limit of the function at that point exists, and 3) the limit is equal to the value of the function at that point. If all three conditions are met, then the function is continuous at that point.
  • Linear and Abstract Algebra
  • Calculus
  • Topology and Analysis
  • Quantum Physics
  • Set Theory, Logic, Probability, Statistics
