How Do You Calculate Voltage Across Each Resistor in a Mixed Circuit?
  • Thread starter Thread starter the_d
    Resistor Voltage
The discussion revolves around calculating the voltage across resistors in a mixed circuit, specifically focusing on series and parallel configurations. Participants explore various methods and formulas related to Ohm's Law and resistor combinations.
  • Homework-related
  • One participant asks how to find the voltage across each resistor in a circuit with a 12V power source and multiple resistors, indicating a lack of specific values.
  • Another participant notes the need for resistor values and suggests the question may be homework-related.
  • A participant mentions that if resistors are in series, the total resistance should be calculated and Ohm's Law applied to find the current and voltage across each resistor.
  • One suggestion is to simplify the circuit by combining resistors to find an equivalent resistance, with formulas provided for series and parallel configurations.
  • Another participant emphasizes the importance of knowing the total resistance to calculate the current and subsequently the voltage across individual resistors in series.
  • A participant shares a specific example of calculating voltage drop across a resistor using Ohm's Law but expresses confusion over their own calculations, particularly regarding units and results.
  • There is a discussion about the correct conversion of current units when applying Ohm's Law, highlighting a potential misunderstanding in calculations.
Participants express varying levels of understanding and confusion regarding the calculations. There is no consensus on the correct approach or resolution of the issues raised, as multiple interpretations and methods are discussed.
Some participants mention specific values and formulas without fully resolving the assumptions or steps required to apply them correctly. There are indications of missing details in the circuit description and calculations.
the_d
I have a 12V power source in a circuit and 4 resistors in a line and 1 on the side how do i find the voltage across each resistor?:confused:
You haven't given us resistor values and your description is vague. Oh yeah by the way, this sounds like homework.
Do you have a diagram?
From your description it seems like all of the resistors are in series. Do you know what to do when resistors are in series?
After you find that out, use Ohm's Law.
Try to simply the circuit by combining the resistors to get an equivalent circuit. If ur resistors is in series, add the resistance. If in parallel do 1/r+1/r2=1/Requvilant.
Well, asking the current (I) with no resistance is like asking how long is a piece of string to find the total Resistance in a parralel circuit then =
R1 X R2 / R1 + R2
And the current can be worked out by I = V/R
I have a 12V power source in a circuit and 1 resistors in a line of 1k , how do i find the voltage across resistor?
please help me?
i want some basic formula so i can calculate the voltage across each resistor..
thank you
If you have 12 volts across a string of resistors in series. the current flowing is 12 / total resistance.
Say the total resistance is 5430 ohms. The current will be 12 volts / 5430 ohms = 2.21 mA
Now, this current flows through all the resistors in series, so the voltage across anyone of them = I * R.
If R= 337 ohms, then the voltage across it will be 0.00221 amps * 337 ohms = 0.744 volts.You can get the same result by doing it like this: 12 volts * 337 ohms / 5430 ohms = 0.744 volts.
So, if you know the total resistance and the voltage across it, you can work out the voltage across any resistor in the series string.
Hello,
Thanks for reply. i have read somewhere that to find out the voltage across resistor do this
Calculate the amount of voltage drop or reduction in an electrical circuit that has a power source of "100" volts at "0.1" amperes and a resistor of "100" ohms. Using the formula "V=I*R" the equation would result "V= 0.1*100". The answer would be "10" volts. This means that a voltage reduction of "10" volts would occur across the "100"-ohm resistor and the circuit would have only "90" volts of power past the resistor placed in the circuit.
is that right ?
but when i do myself i am not getting correct values.
i have 0.02 mA and 1kohms but when i multiple that i write this way :
0.02 * 1000 = 20v
this is not right i have 12v main power and after doing this i am getting 20v how it will subtract 20 from 12.
then i found 1 more simple formule to figure it out what resistor i need for any object,
e.g.
r = es - eb / i
12v - 5v / 0.02 = 350 ohms
is this also right ?
please help me...
The Ohms Law calculations have to be done with Volts, Amps and Ohms.
So, if you have 0.02 mA you need to convert this to 0.00002 Amps before doing the calculation.
So this one:
should be
7 / 0.00002 = 350 K
  • · Replies 16 ·
  • · Replies 33 ·
