Is it intuitive that the Energy levels
The discussion revolves around the energy levels of an electron in a one-dimensional infinite potential well, focusing on the relationship between the length of the well and the energy levels. Participants explore the intuition behind this relationship, considering both classical and quantum mechanical perspectives.
  • Some participants assert that the energy levels of an electron in a 1D infinite well decrease as the length of the well increases, referencing the solution to Schrödinger's equation.
  • One participant questions whether the dependence of energy levels on the length of the well is intuitive, suggesting that a longer well might allow for a more even distribution of energy across positions within the well.
  • Another participant introduces the idea that probing smaller distances requires higher energy, linking this to the uncertainty principle and momentum considerations.
  • Some participants express skepticism about classical intuitions regarding energy, arguing that classical reasoning may not apply to quantum scenarios, particularly regarding the fixed nature of energy in different well sizes.
  • A later reply emphasizes that the kinetic energy relates to the curvature of the wavefunction, suggesting that a narrower well leads to greater energy due to increased wavefunction bending.
  • One participant reflects on their earlier intuition, acknowledging that classical reasoning may not hold in quantum mechanics and questions whether their understanding is incorrect in a quantum context.
Participants express differing views on the intuitiveness of the relationship between energy levels and well length, with some arguing that classical intuition fails in this context. There is no consensus on whether the initial assumptions about energy being fixed are correct in quantum mechanics.
Participants highlight the limitations of classical intuition when applied to quantum mechanics, particularly regarding energy levels and the implications of the uncertainty principle. The discussion also reflects on the mathematical foundations of quantum mechanics without resolving the nuances of these concepts.
pivoxa15
For a 1D infinite well, The energy levels of an electron trapped inside is dependent on the length of the well. The longer the length, the less its energy will be for each state.
I am aware how the formula is derived. The main form of the formula is a solution of Schrödinger's equation which books say is not derived from anything more fundalmental.
But is the fact that the energy levels are depedent on L intuitive? If so why? Could you say that a longer well would mean that the energy of the electron is distributed more evenly for each position x in the well? Hence the energy of the electron is lower at each x in the well for a particular state in a longer well?
Well you know that the physicists always say that to probe smaller distances requires higher energy particles.
Carl
Depends on your intuition. If you are stuck with a classical intuition, it will not help you any.
Here's one kind of intuition : The smaller the box, the greater the momentum uncertainty...
yeah right.
only if your " box " happens to be an atom - in which case - what are you putting in it again?
if not, any basic QM text will tell you that for the same potential you could choose position or momentum eigenstates (or eigenstates of any other operator) which would have, respectively, 0 uncertainty in position and momentum. (moral: math works even if intuition runs awry)
yeahright said:
yeah right.
What?!? Can you explain this a little more...
The kinetic energy is a measure of the curvature of the wavefunction, right? (since [itex]p^2/2m = - \hbar^2 {\partial^2 \over \partial x^2}[/itex]). If you narrow the well, the wavefunction has to "bend" more (recall that it must be zero at the two endpoints) which explains why the energy is larger.
So the reason why E is depedent on L is because of UP.
When I said intuitive, I meant classically intuitive. Obviously, since the UC is needed, the answer is that it is not intuitive.
Classically, wouldn't it be the case that the energy of an electron is fixed from the start, no matter what the size of the well it is in? Hence intuitively E should not depedent on L. E=E until the electron is given potential or kinetic energy via a force.
Looks like my explanation...
'Could you say that a longer well would mean that the energy of the electron is distributed more evenly for each position x in the well? Hence the energy of the electron is lower at each x in the well for a particular state in a longer well?'
is wrong in the classic sense. Is it wrong in a QM sense as well?
  • · Replies 36 ·
11K
  • · Replies 35 ·
