Differance Between Analogue and Digital TV
  • Thread starter Thread starter James Roberts
    Digital
The discussion focuses on the fundamental differences between analogue and digital TV broadcasting, emphasizing the nature of the signals used. Analogue TV transmits information in its original form, while digital TV converts the information into binary code (0's and 1's) for transmission. This conversion allows for improved signal quality and more efficient use of bandwidth. Participants discourage requests for homework help, suggesting that members should demonstrate their own efforts in understanding the topic. Overall, the conversation highlights the technological advancements that digital broadcasting has introduced compared to its analogue predecessor.
James Roberts
Okie doke,
I need someone here (or a collection of people working in some sort of synchronized fashion) to write for me a 1500 word assignment on the difference physics wise between analogue and digital tv broadcasting.
Have fun doing it. :D
Once upon a time, TV was crap. Then along came digital TV and it got worse...
Welcome to PF,
let me share this quote from a great person with you. :)
Hootenanny said:
One is also expected to show ones efforts.
Please do not ask members of PF to do your homework for you, we are far pass that stage, but we can help. :)
Delzac
and don't forget more expensive.
its just the difference in the kind of signal. analoge actually sends the information as it is, whereas digital converts it to 0's and 1's first then sends it as this digital information which is then decyphered on the other side
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
