Thread Closed
Salt Tank - Differential Equation
Share Thread Thread Tools
Sep19-06, 02:21 PM   #1
This problem has been perplexing me all week, it doesn't look hard but somehow I can't get the right answer. The question is -
A salt tank of capacity 500 gallons contains 200 gallons of water and 100 gallons of salt. Water is pumped into the tank at 3 gallon/min with salt of 1 lb/gallon. This is uniformly mixed, on the other end end water leaves the tank at 2 gallon/min. Setup a equation that predicts the amount of salt in the tank at any time up to the point when the tank overflows.
What I wrote was dy/dx = rate in - rate out
dy/dx = 3*1 - 2*Q(t)/(200+t)
Where Q(t) is the amount of salt in the tank. And 200+t represents the increasing volume of water in the tank. This equation doesn't give the correct answer, I have tried tacking 100 lbs of salt so that it becomes dy/dx = 3*1 - 2*(Q(t)+100)/(200+t)
but nothing seems to work. Can someone help me setup the correct equation?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Sep19-06, 04:20 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Lancen
Okay, good start. Although it would be better to state what y and x mean! I would have guessed, since the problem asks you to set up "equation that predicts the amount of salt in the tank at any time" that y(x) was the amount of salt, in pounds, in the tank at time x in minutes, except that you then declared that Q(x) is the amount of salt in the tank!
Perhaps explicitly writing "y(x) is the amount of salt in the tank after x minutes" would help you remember what you are doing!
If y(x) is the amount of salt in the tank, in pounds, after x minutes, then, yes, dy/dx= rate in- rate out. Since you know "Water is pumped into the tank at 3 gallon/min with salt of 1 lb/gallon", you know that salt is coming at 3 gallons/min*1lb/gal= 3 lb/gal. If the amount of salt in the tank is y(x) and the amount of water is 200+ (3-2)x = 200+ x then the density of salt is y/(200+x) pounds/gal and so the rate out is (y/(200+x))*2 gal/min= 2y/(200+x) lbs/min.
dy/dx= 3- 2y/(200+x)
As I said you have confused yourself by using different letters to represent the same things. It is a really good idea to write out exactly what each letter represents so you won't do that. In order that dy/dx represent the rate at which salt is coming in, it is necessary that y= amount of salt in the tank and x= time the salt has been coming in. But then you have used "Q(t)" and "t" to represent the same things!
Nov30-08, 05:45 AM   #3
I think this is the right ODE setting and its solution:
Y’= inflow of salt – outflow of salt
Y’= 3 – 0.01y
Y’= -.01 (y –300)
dy/dt = –.01 (y–300) dt
dy/(y–300)= –.01 dt
Integrate both sides yields:
∫dy/(y–300)= ∫ –.01 dt
ln Iy-300I= –.01t + c
Take exponential for both sides:
Y–300= ℮^(-0.01t + c)
Y = 300 + ce^(-0.01t)
At Y(0)=100 , at t=0 there was 100 lb of salt (initial points)
Substitute to find C:
100= 300 + Ce^(-0.01(0))
So c= –200
Y = 300 – 200℮^(-0.1t)
When salt (y) is 250 lb (as 100 lb is in 200 gallon, so in 500 gallons (capacity of the tank) there is 250 lb of salt, when this is reached tank overflows:
250 = 300 – 200℮^(-0.01t)
50 = 200℮^(-0.01t)
0.2= ℮^(-0.01t)
Ln 0.2= -.01t
-1.609=-.01t
t = 160.94 minutes,
So after 160.94 minutes (2.68 hours) the tank will overflow.
Nov30-08, 09:33 AM   #4
This^
Thread Closed
Thread Tools
Similar Threads for: Salt Tank - Differential Equation
Thread Forum Replies
Differential equation reducible to Bessel's Equation Differential Equations 9
Solving a partial differential equation (Helmholtz equation) Differential Equations 7
Differential Equation - Brine Solution Entering Tank Calculus & Beyond Homework 4
differential equation tank problem Differential Equations 5
Laplace's Equation and Seperation of Multivariable Differential Equation Introductory Physics Homework 2
