How did they calculate the speed of light?
The discussion revolves around the historical and modern methods used to calculate the speed of light, touching on various experiments and theoretical predictions.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants explore different experimental methods, including the synchronization of clocks and the use of astronomical bodies. Questions arise about the practicality of these methods and the historical context of the measurements.
Several participants provide insights into different experiments, such as those involving Jupiter's moons and modern laser measurements. There is an exchange of information, but no consensus has been reached regarding the most significant method or the details of each approach.
Some participants note the constraints of laboratory measurements versus astronomical observations, as well as the specific experiments that are of interest for research purposes.
crystal cascade
Just wondering as to the details of the experiment...
Well, a simple method is to take two clocks, synchonize them, separate them, and then send pulses between them. If you record the distance and times for each event on each clock, then you can use d=r*t. Of course, that isn't really practical on laboratory scales, but it can be done using astronmical bodies where the distances are suitably large. I believe that one experiment involved recording the precise times that a moon of Jupiter was covered and uncovered by the planet, and extrapolating the speed of light from the change in distance and the knowledge of orbital motion.
The modern method for determining the speed of light was developed by K. M. Evenson et al. It relies on separate mesurements of wavelength and frequency emitted by a stabilized laser. They achieved the value c=2 999 792 458 m/s, which has uncertainty of only 1 m/s.
Theoretically Maxwell predicted that self-supporting electromagnetic waves must propagate at speed [tex]c=\frac{1}{\sqrt{\mu_0\epsilon_0}}[/tex]
for more info, check out:
http://nvl.nist.gov/pub/nistpubs/sp958-lide/191-193.pdf
Here's a very nice website that answers your question:
http://www.what-is-the-speed-of-light.com/
The first accurate measurement of the speed of light was done by timing when Jupiter's moons moved out from behind it.
wow thanks :) I knew one of the experiments had something to do with the moons of jupiter...the one my teacher wanted us to research was Mickelson's
  • · Replies 21 ·
  • · Replies 93 ·
  • · Replies 51 ·
