Calculating Molar Concentration of Diluted HCl Solution
  • Thread starter Thread starter fish
To determine the molar concentration of diluted hydrochloric acid after mixing 25 mL of 12 M HCl with 475 mL of distilled water, the formula c1v1 = c2v2 is applied. The initial calculation suggests a concentration of 0.63 M, derived from multiplying 25 mL by 12 M. However, the correct approach considers the total volume of the solution, which is 500 mL. The total moles of HCl in the solution is calculated as 0.3 moles (from 25 mL of 12 M HCl), leading to a final concentration of 0.60 M when divided by the total volume of 0.5 L. This aligns with the textbook answer, confirming that the molarity of the diluted hydrochloric acid is indeed 0.60 M.
fish
If 25 mL of 12 M HCl are added to 475 mL of distilled water, what is the molar concentration of the diluted hydrochloric acid?
c1v1=c2v2
25*12=475c
c=.63 M HCL
book has the answer as .60 M HCL
Isn't the answer .63?
Chemistry news on Phys.org
"25*12=475c"
Think about this a moment; you've asserted something different from the problem statement, "25 mL of 12 M HCl are added to 475 mL ---."
Your total volume is 500ml, and you have 12 moles. 12moles/.500L is?
this seems to work, .30 mol/.500L = .60 M
No u have 12/40=0.3 moles
and now volume is 500mL
therefore molarity= 0.3*2=0.60
it is right way fish
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
