Free-floating top; relation of precession angle and precession and spin rates
The discussion centers on the relationship between precession rate, precession angle, and spin rate for freely spinning objects, specifically baton-like shapes in zero gravity. A formula is derived that relates these variables, indicating that for objects with an axis of symmetry, the precession is slow compared to the spin rate when the moment of inertia in the second axis is significantly greater than in the first. The analysis highlights that precession can occur even in weightless conditions, as demonstrated by a practical experiment with a spinning pen. The conversation also touches on the broader implications of precession in celestial bodies, such as Earth's precession due to gravitational forces. Overall, the findings provide a mathematical framework for understanding the dynamics of spinning objects in a frictionless environment.
hkyriazi
Does anyone know of a formula describing the relationship between precession rate, precession angle, and spin rate for a top (or gyroscope, or any hard, non-spherical object) spinning freely, in zero gravity? All the analyses I've been able to find are for tops under constant torque (gravity), or with their tip held in place in some way.
Specifically, I'm trying to analyze what happens to a baton-like object (like the ones that majorettes twirl in marching bands) as it goes from pure twirling (which has, by my definition, an axial spin rate of zero, and 90 deg precession angle), under a series of frictionless taps at opposite ends and sides, to the pure spinning state (zero deg precession angle, zero twirl/precession rate, and much higher spin rate than the initial twirl/precession rate).
I've had this posted for almost a full day, with no takers, so I'll add that the Earth is known to precess once every 26,000 years or so, but the explanations I've found on the web seem to attribute this to the constant force the equatorial bulge feels from the sun and other planets.
In order to prove to myself that an object can indeed precess under weightless and force-free conditions, I spun a smooth surfaced pen off my fingertips into the air (one must spin it very rapidly, with a finger-snap movement) with a slight jerk as I let it go, and could see (with a good spin and flick) that it precessed nicely until it hit the floor. (If one does this with a pencil, which is usually hexagonal in cross-section, the air resistance effect is so great that it causes very bizarre movements through the air, obscuring the precession.)
--Harold Kyriazi
Well, you know what they say. Better late than never.
Objects like batons, footballs (American), some pens and most pencils have one axis of symmetry, and luckily those are the easy ones to analyze. Any solid object has three principal moments of inertia: I1, I2, and I3. For an object with an axis of symmetry, two of these are equal, say I2 = I3 = I. You can always label the principal axes so this is the case.
In the attached diagram, there is a potato shaped object representing an ellipsoid of revolution. \bold{\omega} is the total angular velocity of the potato, which is decomposed into the spin angular velocity \bold{\omega}_s and the angular velocity of precession \bold{\omega}_{pr}. The precession angular velocity is directed along the constant angular momentum vector L. Also shown are the unit vectors e1 and e2, which are the the directions of the first and second principal axes at that instant.
Since the potato is assumed to have an axis of symmetry, at any instant we can choose the second and third principal axes such that the angular momentum and angular velocity lie in the plane of the first two principal axes. Let \omega_1 and \omega_2 be the components of the total angular velocity along the 1 and 2 axes, respectively. Then the components of the angular momentum are L_1 = I_1 \omega_1 and L_2 = I_2\omega_2. Then from the diagram
L_2 = L\sin\theta = I_2\omega_2
\omega_2 = \omega_{pr}\sin \theta
from which we get
\omega_{pr} = \frac{L}{I_2}. (*)
But we also have
L_1 = L \cos \theta = I_1 \omega_1 = I_1 (\omega_s + \omega_{pr}\cos\theta). (**)
Now from (*) we get
\omega_{pr} \cos \theta= \frac{L\cos\theta}{I_2}.
and from (**) we get
L \cos \theta =I_1 (\omega_s + \omega_{pr}\cos\theta), which combined with the previous equation gives
\omega_{pr} \cos \theta = \frac{I_1 (\omega_s + \omega_{pr}\cos\theta)}{I_2}
This can be solved to get
\frac{I_2 - I_1}{I_1}\omega_{pr} \cos \theta = \omega_s, which relates the spin rate, precession rate, and precession angle.
For a baton, I2 >> I1, so the precession is slow compared to the spin rate.
Thanks, Techmologist. Better late than never to see the better-late-than-never answer, too!
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
I passed a motorcycle on the highway going the opposite direction. I know I was doing 125/km/h. I estimated that the frequency of his motor dropped by an entire octave, so that's a doubling of the wavelength. My intuition is telling me that's extremely unlikely. I can't actually calculate how fast he was going with just that information, can I? It seems to me, I have to know the absolute frequency of one of those tones, either shifted up or down or unshifted, yes? I tried to mimic the...
