Thread Closed
Electric Fields
Share Thread
Jan26-07, 10:07 AM   #1
Electric Fields
A very long, straight wire has charge per unit length 1.47×10^10
At what distance from the wire is the electric field magnitude equal to 2.57 N/C
2. Relevant equations
E = lambda / (2*pi*E_o*r)
E_o = 8.85*10^-9
3. The attempt at a solution
2*pi*E_o*E / lambda = r
Is this correct so far?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan26-07, 10:33 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Looks fine you just need to plug the numbers in.
Jan26-07, 02:21 PM   #3
r = 2*pi*(8.85*10^-9)*(2.57) / (1.47*10^-10)
I'm not sure if lambda is represented correctly and is E just 2.57 or should it be 10^(something)
Jan26-07, 02:39 PM   #4
Recognitions:
Electric Fields
E will just be 2.57 as stated in the problem. Why are you worried about lambda?
Jan26-07, 02:50 PM   #5
I wasn't sure if lambda = 1.47*10^-10
Jan26-07, 02:53 PM   #6
Recognitions:
probably more likely to be x10-10 than the other way round.
Jan26-07, 02:55 PM   #7
Quote by Kurdt View Post
Thats what I had before 1.47 x 10^-10
Jan26-07, 02:57 PM   #8
Recognitions:
What is it in the question?
Jan26-07, 02:59 PM   #9
The original question was if lambda = 1.47 x 10^-10.
You said yes, so I just wanted to make sure.
Jan26-07, 03:02 PM   #10
2*pi*(8.85*10^-9)*(2.57) / (1.47*10^-10) = r
This evaluated to:
r = 972
The online program says I'm off by an additive constant??
Jan26-07, 03:16 PM   #11
Recognitions:
I've just noticed you have E on top of the fraction and lambda below. You need to swap these two so the equation is:
[tex] r=\frac{2k\lambda}{E} [/tex]
Like I said in a previous thread, try manipulating equations with just their symbols until the very last moment. Its a lot easier to spot problems that way.
EDIT: Sorry [tex] k=\frac{1}{4\pi \epsilon_0} [/tex]
Jan26-07, 03:27 PM   #12
2* (1/4*pi* 8.85*10^-9) * (1.47*10^-10) / 2.57
= 1.03×10−3
Still says I'm off by a additive constant.
Jan26-07, 03:30 PM   #13
Recognitions:
I think you've made a mistake in the calculation as i get a different answer. Try it again you're 3 orders of magnitude out.
Jan26-07, 03:33 PM   #14
Recognitions:
Where did you get that value of epsilon nought from? It should be: 8.85x10-12
Jan26-07, 03:35 PM   #15
I need to be more careful from paper to online input. I have so much scratch work, some how I changed the epsilon value =[
Jan26-07, 03:38 PM   #16
Recognitions:
No problem. Try a bit of latex for your equations it should help in future to diagnose problems quicker
http://www.physicsforums.com/showthread.php?t=8997
Thread Closed
Similar discussions for: Electric Fields
Thread Forum Replies
Concept Question - Electric Potential, and Electric Fields Introductory Physics Homework 8
Electric fields of infinite line & electric dipole Introductory Physics Homework 3
Electric fields, magnetic fields and Lorentz frames Advanced Physics Homework 5
Physics Questions - Electric Fields, Electric Potential, etc Introductory Physics Homework 3
Electric charge and fields: uniform electric field Introductory Physics Homework 1
