| Thread Closed |
Heat produced from Brake Pad Friction material? |
Share Thread | Thread Tools |
| Feb21-07, 05:48 PM | #1 |
Hi all,
My model of a car brake system is intended to monitor the rate at which heat increases/decreases as friction between a brake pad and disc increases. My equation for the force transmitted to the disc is: Force = (δP x Ac) x μb where δP is the pressure generated at the master cylinders Ac is the area of the caliper pistons and μb is the coefficient of friction of the brake pad material. how can i find the heat generated fromt his equation, any suggestions? thanks in advance |
| Feb21-07, 09:18 PM | #2 |
I am no expert but the brakes convert kinetic energy into heat. So if you know the car's velocity and mass, you can figure out how much kinetic energy will be converted to heat.
Also, if you know how much force the brake is applying and the distance over which it is applied, you can figure out how much energy was converted to heat. |
| Feb22-07, 12:58 AM | #3 |
Now that you know the force F. Just imagine the car is in its stop and you still push the brake: no heat. The work is calculated as : W=FS , then dW=FdS <==> dW/dt=FdS/dt (S is the distance, v: velocity) or power P=Fv. All the work is converted into heat so with that equation, you calculate exactly the heat generated by the brake.
You can also easily compute the heat by : E=mv^2/2. But the mass in this equation is not fix, and the energy E also includes the friction caused by air drag. |
| Feb22-07, 07:54 AM | #4 |
Guys thanks alot for your replies, its much appreciated, i will study what you have said, and if i have any more issues, will post them here....thanks :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Heat produced from Brake Pad Friction material?
| Heat Due to Friction In Brake Pads | Materials & Chemical Engineering | 27 | ||
| Heat dissipation between brake Pad and Disc | Mechanical Engineering | 8 | ||
| Heat dissipation from a brake pad | General Engineering | 11 | ||
| Heat produced on shaking | Classical Physics | 26 | ||
| Heat Due to Friction Between Brake Pads | Classical Physics | 1 | ||
