Law of Cosines Oddities: Solving Triangles with Given Sides and Angles
  • Thread starter Thread starter pugfug90
    Law
The discussion centers around solving a triangle with sides a=6, b=9, and angle C=45 degrees using the Law of Cosines and the Law of Sines. The initial calculation for side c yielded a value of approximately 6.37, leading to conflicting angle results for B, with estimates of 87.5 degrees and 93.3 degrees. The discrepancy arises from the sensitivity of the sine function near 90 degrees, where small changes in input can lead to significant variations in output angles. A recommended approach is to first find the smallest angle to avoid ambiguity, as this ensures the correct solution in SSA cases. The conversation highlights the importance of accuracy and understanding the behavior of trigonometric functions when solving such problems.
pugfug90
Solve triangle having indicated sides and angles.
a=6
b=9
C=45degrees
Law of Cosines
Law of Sines
I did c^2=9^2+6^2-(2*9*6*Cos45 degrees)
c=6.37
Then I did 6.37/cos45 =9/SinB.. That proportion would give me 87.5 derees.. However, the back of my book and..
http://www.trig.ionichost.com/
Says that B is 93.3 degrees..
However, if I were to approach the problem by solving for A (smallest angle) instead of immediately to B (mid sized).. I would get 41.7 degrees..
Then I could do B=180-A-C..or 93.3 degrees..
But still, if I set up a ratio of sin41.7degs/6=sinB/9, that's not 93.3, or 87.5, but 86.2
I'd like to know why math is stupid. And next time, what I should do to know whether 93.3, 87.5, or 86.2 would be the right answer. :smile:
Your problem is you are not working accurately enough.
My calculator gives c = 6.37456
If you use c = 6.37 you get sin B = (9 sin 45)/ 6.37 = 0.99905
If you use c = 6.37456 you get sin B = 0.9983373
If you look at the graph of sin x, it is almost "horizontal" when x is near to 90 degrees and sin x is nearly 1.0
if sin B = 0.9983373 then B = 86.70 or 93.30
if sin B = 0.99905 then B = 87.50 or 92.50
The small change in the value of sin B causes a big change in the value of B
When you found the smallest angle of the triangle by the sine rule, you avoided this problem for two reasons:
1 the slope of the graph of sin x is steeper so there is less error in going from sin x to x
2 you know the smallest angle of a triangle must be less than 90 degrees, so the other solution (A = 130.3) is not possible.
Ok.. So when given SSA, always find the S of the given A.. then find the A of the other smallest S?
Yes that would work.
A more general message to take away from this is: If you are working with any function and you are close to the point where the graph is horizontal (zero slope), then be careful if you are using the inverse function. For example sin x near 90 degrees, or cos x near 0 degrees.
Also!
You can only have the possibility of having 2 solutions with SSA, right?
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
