Thread Closed
Efficiency of a Siphon
Share Thread Thread Tools
Feb25-07, 08:01 AM   #1
(Hope this is in the right forum)
For my A Level coursework I have to do a practical investigation. I'm thinking of doing one looking at the efficiency of a siphon.
One relationship I am going to be looking at is the rate of flow vs height (difference between the two water levels).
Now I'm having a bit of difficulty thinking what else I can look at to give it some decent scope. My teacher hasn't seen this done before so we're a bit uncertain whether it's worth taking forward.
Any suggestions would be appreciated! Thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb25-07, 06:39 PM   #2
Recognitions:
Gold Membership Gold Member
You've chosen a rather difficult subject. The flow of liquids in pipes ( fluid dynamics) is a whole branch of physics with more equations than I could shake a stick at.
Feb26-07, 02:03 AM   #3
Thanks for your reply.
I was thinking of applying Bernouilli's equation to the seperate parts to derive the flow rate, and possibly the maximum height.
Would it be worth varying the diameter of the siphon tube?
Feb26-07, 05:09 AM   #4
Math 2012
Recognitions:
Quote by lapsaJ View Post
Yes it would. (You might expect the flow would be proportional to the cross section area of the tube, but it won't be, for long thin tubes).
Read up a bit about flow in pipes and the effects of viscosity, laminar and turbulent flow, and Reynolds number before you get into this. Otherwise, you will have a very hard time understanding your measurements.
It won't make a very good project when (not if!) you show that Bernoulli's equation doesn't fit any of your results, but you don't have any understanding of WHY that is the case.
Mar15-07, 10:50 AM   #5
Quote by AlephZero View Post
Why isn't the diameter of the siphon tube proportional to the rate of flow for long thin tubes? I am just reading up on theories behind the siphon from journals etc..Just wondering why that's the case (altering the diameter).
Thanks
Thread Closed
Thread Tools
Similar Threads for: Efficiency of a Siphon
Thread Forum Replies
efficiency of siphon Classical Physics 7
what is siphon break and reverse siphon? Mechanical Engineering 0
Siphon Introductory Physics Homework 0
Help with reverse siphon break???? Materials & Chemical Engineering 3
