Thread Closed
T-cyclic Operator - linear algebra
Share Thread Thread Tools
Mar17-07, 05:01 PM   #1
Unhappy
Let T be a linear operator on a vector space V, and suppose that V is a T-cyclic subspace of itself. Prove that if U is a linear operator on V, then UT=TU if and only if U=g(T) for some polynomial g(t).
2. Relevant equations
They suggest supposing that V is generated by v.
and choose g(t) such that g(T)(v) = U(v).
3. The attempt at a solution
I could get some coherent stuff for one way..
=> assume U=g(T), prove UT=TU.
first, {v, T(v), T^2(v), ... , T^n-1(v)} is a basis of V (thus V is n-dimensional).
U=g(T)
let y=U(x) choosem g(t) such that y = g(T)(v).
then UT(x)=U(T(x)) = U(T(a_0v + a_1T(v)+...+a_n-1T^n-1(v)) = U(a_0T(v) + a_1T^2(v) + ... +a_n-1T^n(v))
= a_0UT(v) + a_1UT^2(v) + ... +a_n-1UT^n(v)
then TU(x)= T(U(x))
(where x is a linear comb of basis vectors, x=a_0v + a_1T(v)+...+a_n-1T^n-1(v))
thats as far as i got.. =(
the other direction is more difficult for me.. i'm not really sure where to get the proper expression for g(t) from at all.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar17-07, 06:18 PM   #2
AKG
Recognitions:
Homework Helper Homework Help
if U = g(T), then UT = TU is obvious, you don't need to worry about v's or x's or anything, it has nothing to do with V being T-cyclic, you don't use the hint, etc. For the other direction, use the hint. Since V is T-cyclic, there does indeed exist some v such that v generates V. U(v) is an element of V, and since v generates V, U(v) is indeed equal to g(T)(v) for some polynomial g. Let g be this polynomial. Now just show that for any x in V, g(T)(x) = U(x). Remember that in this direction, you may assume UT = TU.
Mar14-10, 11:47 AM   #3
Hi, sorry for reviving this old thread, but I'm doing the same question.. I know we can assume UT = TU for one direction, but I can't make out what that's supposed to mean..
The two operators commute, so am I supposed to work something from the fact that they commute? ( some property that makes them commute..)
thank you
Mar14-10, 11:11 PM   #4
I tried a couple of promising things, but I'm just blindly stabbing at it . How would I go about coming up with a plan for this? I need to know something about UT = TU... :S
thanks
Thread Closed
Thread Tools
Similar Threads for: T-cyclic Operator - linear algebra
Thread Forum Replies
[SOLVED] linear algebra determinant of linear operator Calculus & Beyond Homework 1
Linear algebra - differentiation operator Calculus & Beyond Homework 3
Linear Algebra: Linear Transformation and Linear Independence Calculus & Beyond Homework 8
Operator algebra question Quantum Physics 8
Differentiate between cyclic and non cyclic phosphorilation in photosynthesis? Biology 0
