Thread Closed
friction between two surfaces
Share Thread Thread Tools
May13-07, 08:02 AM   #1
Question
hi, i am almost done my lab on the coefficient of friction on an inclined plane. I was attempting to prove that the coefficent of static friction would be the same no matter the weight of the mass that was static on the incline. However, i plotted a coefficient versus mass graph, and the line wasn't horizontal (the coefficient changed). My quick question was whether i still need to find the equation for finding the coefficient based on my results, or if i could just conclude that in my case, the coefficient didn't stay constant, and then move to my conclusion
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
May13-07, 08:07 AM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
How did you calculate the coefficient of friction for your results?
May13-07, 08:26 AM   #3
i had an incline, measured the weight of the mass, and changed the angle such that if i increased the angle by a little bit, the mass would slide. I did this for several different masses and recorded the angle. I then used a freebody diagram and the equation for static friciton (u = Fmax/R)
May13-07, 08:28 AM   #4
Recognitions:
And how did you calculate the normal reaction force?
May13-07, 08:34 AM   #5
R = mg cosx
F = mg sinx
so in essence, the coefficient was tanx
May13-07, 08:39 AM   #6
technically, all i need to know is whether i would have to process the graph to find a relation between weight and the coefficient (although i know that technicallly the coefficient is independant of mass) if all i wanted to prove in the lab was that the coefficient was independant of mass (and in my case, my experimental data didn't prove it)
May13-07, 09:03 AM   #7
Recognitions:
Your not actually plotting [itex]\mu[/itex] vs. [itex]m[/itex] what your actually plotting is [itex]\tan\theta[/itex] vs. m since;
[tex]\mu = \frac{F}{R} = \frac{mg\sin\theta}{mg\cos\theta} = \tan\theta[/tex]
May13-07, 11:16 AM   #8
but since tanx = u, so why should it matter whether you plot u vs. m or tanx vs m?
May13-07, 11:20 AM   #9
Recognitions:
Quote by jamesyboy1990 View Post
Indeed, [itex]\tan\theta = \mu[/itex], but are you keeping the angle constant?
May13-07, 11:25 AM   #10
no, because the greater mass wouldn't stay static at the certain angle, so it would decrease.
if i am trying to prove that the coefficient should stay the same, and it doesn't in my experiment, do i have to do more, or can i just stop once the graph shows that the coefficient changed?
May13-07, 05:03 PM   #11
i thought that: Frict max=mu R
so for your experiments to prove mu is irrespective of mass the particle has to be on the point of slipping
that may be too simple i am only doing as physics and you guys might be talking about something higher tho from mechanics mu is >= to R/Frict max
(sorry about symbols ect)
May13-07, 07:38 PM   #12
honestly, the only question i wanted answered was in respect to the set up to the lab. Once you process enough data to prove/disprove the purpose of the lab, do you have to do any more processing, or can you just go straight to conclusion/evaluation?
Thread Closed
Thread Tools
Similar Threads for: friction between two surfaces
Thread Forum Replies
Rotating 2D coordinate geometry/conic sections into 3D - how? General Math 7
Intersection between surfaces Calculus & Beyond Homework 2
Smoothness of surfaces Calculus 5
Smoothness of surfaces Calculus 0
nodal surfaces? Chemistry 5
