How Do You Solve This High Pass Filter ODE Problem?
  • Thread starter Thread starter brad sue
    Signals System
The discussion revolves around solving a high pass filter ODE, specifically the equation dx[t]/dt = y[t]/RC + dy[t]/dt. The initial solution provided involves an integral with x'[\lambda], but the task is to express y[t] as an integral of x[\lambda]. Participants suggest using integration by parts to achieve this, emphasizing that t is a constant during integration, not a variable. Clarifications highlight the importance of maintaining the form t - λ in the integral while recognizing that λ is the variable of integration. The conversation concludes with the poster planning to redo their computations based on the feedback received.
brad sue
Hi,
I have this problem about signals that I have a little trouble to finish:
I attached a small figure of the circuit.
I cannot figure out the answer and I struggled for 2 days.
It is a High pass filter, and the ODE of the circuit is:
\frac{dx[t]}{dt}=\frac{y[t]}{RC}+ \frac{dy[t]}{dt}
the solution for the equation is (according to the hint given by the homework):
y[t]=\int_{-\infty}^{t} e^{-(t-\lambda)/\tau}x'[\lambda] \,d\lambda (1)
But the question said:
Find the solution of the ODE to obtain y[t] as some integral of x[t].
This implies taking away the x'[\lambda] in (1) and replace by x[\lambda].
the hint suggested us to use the integration by part to the solution y[t].
I chose x'[t] for v' and the exponetial function as u.
\int_{a}^{b}u.v'd\lambda =[u.v] -\int_{a}^{b}u'. vd\lambda
Doing this, I got:
y[t]=x[t]+\lambda\int_{-\infty}^{t}x(\lambda)e^{-(t-\lambda)/\tau} \,d\lambda
My problem is that by intergrating, even though I took away what I wanted, I have introduced the variable t. I don't know if it is a problem. I am not sure of the answer.
My second question is the following:
Find the impulse response function h[t] so that the solution is has the form:
y[t]=\int_{-\infty}^{+\infty}h(t-\lambda) x(\lambda) \,d\lambda
Hint: if you find a lonely x(t), remenber that: x[t]=\int_{-\infty}^{+\infty}\delta(t-\lambda) x(\lambda) \,d\lambda
\delta(t) is the delta function.
please can I have help with this problem?
Thank you
brad sue said:
Hi,
Doing this, I got:
Thank you
In the integral t is not a variable, it is a constant, since the integration variable is lambda. You can make e^{-(t-\lambda)} = e^{-t}e^\lambda then take e^{-t} outside of the integral.
Thank you CEL but I think that I need to keep the form so that I always get the t-\lambda as argument.
Even if you want to keep the form t-\lambda, t is still a constant and not a variable. The only variable is still \lambda .
When one does
the integral involves the frequency domain, and lambda (frequency) is the variable, not t.
Frquency domain is the basis of Fourier and Laplace transforms and analyses, as opposed to the time-domain.
If x(t) = eat, then x'(t) = a eat = a x(t) assuming that x'(t) = d x(t) / dt
and the other part of that is d [x(t)]/da = t eat = t x(t)
Thank you Astronuc and CEL,
I 'll redo my computations. I will let you know if I still have an issue.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
