Thread Closed
Projectile Motion
Share Thread Thread Tools
Sep20-07, 06:41 AM   #1
Projectile Motion
airplane files horizontally with constant speed of 260 mph at an altitude of 500m. Ignore height of this point above sea level. Assume acceleration due to gravity is g= 9.8m/s^2
After ejecting a package from the plane, how long will it take for it to reach sea level from time it is ejected? Assume package has an initial velocity of 260mph in the horizontal direction. What is the speed of the package when it hits the ground (mph)?
2. Relevant equations
x = u t+ (1/2) a t^2
sqrt vx^2 + vy^2 (I don't know how to incorporate that into finding the speed though)
v=voy+ay(t)
3. The attempt at a solution
I've already found it will take 10.1s for the package to hit the ground and the horizontal distance it should be released from the plane is 1170m...but I'm not sure about finding vy. Please help. Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Sep20-07, 06:56 AM   #2
Admin
One has to find the horizontal velocity vx and the vertical velocity vy, and add the two vectors.
v = [tex]\sqrt{v_x^2\,+\,v_y^2}[/tex]
Sep20-07, 06:57 AM   #3
But I don't know vy!
Sep20-07, 06:57 AM   #4
Recognitions:
Homework Helper Homework Help
Projectile Motion
it appears that v_y was initially zero, for there was only horizontal velocity of 260mph... so simply v_y = u_y + a t and the speed you are after is probably the magnitude of your vector (need to combine the x and y components)
Sep20-07, 09:09 AM   #5
Admin
Quote by Idealism_Theory View Post
As mjsd indicated, assume that the package is dropped with zero vertical velocity, then accelerates downward under the influence of gravity.
One was able to find the time at which the package struck the ground. One should be able to find the vertical velocity after falling 500 m with an acceleration of g.
Thread Closed
Thread Tools
Similar Threads for: Projectile Motion
Thread Forum Replies
Projectile motion and circular motion questions Introductory Physics Homework 3
Projectile Motion assignment - Building a projectile launcher Introductory Physics Homework 3
Projectile Motion and Relative Motion Principles Introductory Physics Homework 1
Projectile Motion + Linear Motion = Problem Introductory Physics Homework 3
Uniform Circualr Motion with Projectile Motion problem (Extremely confusing): Introductory Physics Homework 4
