Lenses~focal length, object & image distance
In summary, the focal length of a convex lens is 16 cm. To form a real image twice as large as the object, the object should be placed at a distance of 24 cm from the lens. To form a virtual image twice as large as the object, the object should be placed at a distance of 8 cm from the lens. The sign conventions for the lens formula should also be considered when solving these problems.
vickilcw
1)Question:
The focal length of a convex lens is 16cm.
Where must be an object be placed so that the image formed by the lens is
a)real and twice as large
b)virtual and twice as large
2)Related equation:
i)magnification=(height of image) over (height of object)
ii)magnification=(image distance) over (object distance)
3)Attempt to this question:
a)As the manification is 2,the distance between the image and the lens (let this
distance be i cm)is twice of that between the object and the lens (let this distance
be b cm).
Thus, i=2b
As 2F'>b>F',therefore, 32>b>16
and i>2F, thus, 2b>32 (i.e.b>16)
To conclude, 32>b>16,and hence, the object should be placed 16to32 cm from the
lens.
b)The object distance (let it be a cm) is less than F', thus, a<16.
:confused:I don't know how to calculate the exact number of object distance in these 2 questions.:confused:
f-focal length
s-object distance
s'-image distance
M-magnification
a. To form a real image twice as big as the object, we let the magnification be M=-2 (check out the sign convention at the bottom in case you don't know yet)
But, M=-(s'/s), and since we're solving for s, we manipulate the eqn above to get s'=-sM. Now, substitute that to the lens eqn, (1/f)=(1/s)+(1/s'), and you'll get (1/f)=(1/s)-(1/sM). Simplifying, we get s=[f(M-1)]/sM
There you go :D All you have to do next is to substitute all the given values to the equation and you'll get s=24 cm. For part b, you just have to use M=2, and the answer's s=8 cm. Notice that both answers are positive - this is because we're dealing with a real object.
Hope this helps you :D
*Sign conventions*
f: (+) for converging/convex lens, (-) for diverging/concave lens.
s: (+) if object is on the same side of the lens as the incident light (real object), (-) if the object is on the side of the lens opposite the incident light (virtual object)
s': (+) if the image is on the side of the lens opposite the incident light (real image), (-) if the image is on the same side as the incident light (virtual image)
M: (+) if the image has the same orientation as the object (virtual image), (-) if the image is opposite to the orientation of the object (real image)
timeforplanb said:
f-focal length
s-object distance
s'-image distance
M-magnification
*Sign conventions*
Nice of you to solve the problem for OP! Perhaps you could have asked whether OP was familiar with the lens formula(e).
1. What is the focal length of a lens?
The focal length of a lens is the distance between the lens and the point where light rays converge to form a sharp image. It is typically measured in millimeters and determines the magnification and field of view of the lens.
2. How does the focal length affect the image produced by a lens?
The focal length of a lens affects the magnification of the image. A shorter focal length will produce a wider field of view and a smaller image, while a longer focal length will produce a narrower field of view and a larger image.
3. What is the difference between object distance and image distance?
The object distance is the distance between the object being photographed and the lens, while the image distance is the distance between the lens and the image formed on the sensor or film. These distances are important for determining the magnification and sharpness of the image.
4. How do I calculate the image distance given the focal length and object distance?
The image distance can be calculated using the thin lens equation: 1/f = 1/o + 1/i, where f is the focal length, o is the object distance, and i is the image distance. Simply plug in the values for f and o to solve for i.
5. Can I change the focal length of a lens?
Yes, on most cameras the focal length can be adjusted by zooming in and out. Some lenses also have a fixed focal length, while others have a variable focal length. Additionally, you can use different lenses with different focal lengths to achieve different perspectives and magnifications in your photos.
