| Thread Closed |
Laser beam diffraction |
Share Thread | Thread Tools |
| Dec1-07, 06:03 PM | #1 |
A scientist needs to focus a helium-neon laser beam (lamda = 633nm) to a 10 micrometre diameter spot 8.0 cm behind the lens. a) What focal-length should she use? b) What minimum diameter should she use? 2. Relevant equations w = (2.44lambda * focal length) / diameter theta = 1.22lamda/diameter Wmin is apprx equal to 2.5lambda....apparently, but if you have a seperate method ignore this. 3. The attempt at a solution i attempted to calculate w through 2.5lambda, then use that to calculate the focal length. the answer i got was 0.001cm. |
| Dec1-07, 08:37 PM | #2 |
I cannot seem to find any modification of this equation anywhere, but it seems that this is the only equation that is used to solve this problem
| Dec1-07, 10:35 PM | #3 |
Oh! So did you get the right answer using that formula?
| Dec1-07, 10:54 PM | #4 |
nope, still nothing, anyone know anything??
| Thread Closed |
| Thread Tools | |
Similar Threads for: Laser beam diffraction
| Laser Beam Question | Engineering, Comp Sci, & Technology Homework | 3 | ||
| laser beam | Introductory Physics Homework | 1 | ||
| Green laser beam | General Discussion | 11 | ||
| Laser beam Dots.. | General Physics | 5 | ||
| Bending a laser beam ?!!! | General Physics | 6 | ||
