Effect of Changing Magnetic Field on Flux through a Coil
The discussion revolves around the effect of changing magnetic fields on magnetic flux through a wire coil. The original poster presents a scenario where the magnetic field's magnitude increases while its direction remains unchanged, prompting questions about how this affects the magnetic flux through the coil. Participants explore the relationship between magnetic flux, magnetic field strength, and the orientation of the coil.
  • Participants discuss the formula for magnetic flux and its dependence on the area and angle relative to the magnetic field. There are attempts to reason through the implications of changing the magnetic field strength and the orientation of the coil.
The conversation includes various interpretations of how magnetic flux is affected by changes in the magnetic field and the orientation of the coil. Some participants suggest that the flux increases with the strength of the magnetic field, while others question the impact of the coil's orientation on the flux. There is a mix of agreement and differing viewpoints on the reasoning presented.
Participants are working under the constraints of a homework assignment and are seeking validation for their reasoning and answers. The discussion includes multiple scenarios regarding the orientation of the coil and the conditions under which the magnetic flux is evaluated.
cse63146
You hold a wire coil perpendicular to a magnetic field B. If the magnitude of B increases while its direction remains unchanged, how will the magnetic flux through the coil change?
Check all that apply:
The flux is unchanged because the position of the coil with respect to B is unchanged.
The flux increases because the magnitude of B increases.
The flux decreases because the magnitude of B increases.
The flux is unchanged because the surface area of the coil is unchanged.
[tex]A_{eff} = Acos\vartheta[/tex]
According to the formula - [tex]A_{eff} = Acos\vartheta[/tex], the magnetic flux is determined by the area. I believe the answer is "flux is unchanged because the surface area of the coil is unchanged" since in the problem, only B is changing.
Am I right?
Magnetic flux linkage is given by:
[tex]\Phi =BAcos\theta[/tex]
Ah, since magnetic filed is directly proportional to the magnetic flux, it would make the solution - The flux increases because the magnitude of B increases, correct?
Correct.
Thanks, but another question "unlocked" itself after I finished the first one:
If B is kept constant but the coil is rotated so that it is parallel to B, how will the magnetic flux through the coil vary?
The flux is unchanged because the magnitude of B is constant.
The flux increases because the angle between B and the coil's axis changes.
The flux decreases because the angle between B and the coil's axis changes.
The flux is unchanged because the area of the coil is unchanged.
So [tex]\Phi = ABcos\vartheta[/tex] and since the coil is parallel to B, it means [tex]\vartheta0[/tex] and [tex]cos\vartheta = 1[/tex] so in this case [tex]\Phi = AB[/tex] and since B is constant and so is A, there are two answers:
i) The flux is unchanged because the magnitude of B is constant.
ii) The flux is unchanged because the area of the coil is unchanged.
Correct?
can someone just double check me reasoning/answer, as this is the last question on my assigment.
Thank You.
When the coil is perpendicular:
[tex]\theta=0[/tex]
When the coil is parallel, the tilt is 90 degrees, and the magnetic flux is 0. You can imagine flux as the number of field lines passing through the area. If the coil is parallel to the magnetic field, none of the field lines get passed the area bounded by the coil.
Since it's being rotated so it would be parallel, [tex]\vartheta[/tex] is decreasing so the answer is:
The flux decreases because the angle between B and the coil's axis changes. Correct?
Yes.
Thank you both for all your help.
