Thread Closed
Rigid Bodies; Euler's Eq of Motion derivation
Share Thread Thread Tools
Mar24-08, 04:31 PM   #1
Problem
Derive Euler's equations of motion for a rigid body from the Lagrange formulation (for generalized coordinate [tex]\psi[/tex], the third Euler angle).
Applicable Formulae
Euler's equations of motion (what we are trying to derive) are:
[tex]I_{1} \dot{\omega_{1}} - \omega_{2} \omega_{3} (I_{2}-I_{3}) = N_{1}[/tex]
[tex]I_{2} \dot{\omega_{2}} - \omega_{3} \omega_{1} (I_{3}-I_{1}) = N_{2}[/tex]
[tex]I_{3} \dot{\omega_{3}} - \omega_{1} \omega_{2} (I_{1}-I_{2}) = N_{3}[/tex]
Lagrange Formulation:
[tex]\frac{d}{dt} \left( \frac{\partial T}{\partial \dot{q_{j}}} \right) - \frac{\partial T}{\partial q_{j}} = Q_{j} [/tex]
Attempt at a solution
It seems I need an expression for the kinetic energy T of the rigid body in terms of the Euler angles. I would then plug that into the Lagrange equation above for [tex]\psi[/tex], and reduce it to the desired form.
The kinetic energy is given by:
[tex]T = \frac{\vec{\omega}\cdot\bar{I}\cdot\vec{\omega}}{2}[/tex]
and the angular velocity in terms of Euler angles is:
[tex]\vec{\omega_{x,y,z}}=\left( \begin{array}{c} \dot{\phi} sin\theta sin\psi + \dot{\theta} cos\psi \\ \dot{\phi} sin\theta cos\psi - \dot{\theta} sins\psi \\ \dot{\phi}cos\theta + \dot{\psi} \end{array} \right) \cdot \left( \begin{array}{c} \hat{x} \\ \hat{y} \\ \hat{z} \end{array} \right)[/tex]
I've already started working on it, but it seems like a lot of work. Am I on the right track, or is there something I'm missing here?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Thread Closed
Thread Tools
Similar Threads for: Rigid Bodies; Euler's Eq of Motion derivation
Thread Forum Replies
Rigid bodies Introductory Physics Homework 5
Motion of Rigid Bodies Introductory Physics Homework 9
kinetics of rigid bodies Advanced Physics Homework 2
Rigid Bodies and rotatational motion Introductory Physics Homework 4
question concerning rigid bodies Classical Physics 1
