How Long Does It Take for Connected Water Tanks to Equalize Pressure?
  • Thread starter zax
In summary, the conversation discusses a problem involving two water tanks with different pressure and how to calculate the time it takes to reach the same pressure when they are connected together. The concept of Poiseuille's law is mentioned, as well as the use of the Darcey Weisbach equation to calculate flow restrictions. The importance of minimizing irreversible pressure drop and accounting for acceleration losses is also discussed. A flow analysis is recommended for each line to avoid any surprises.
zax
Hey, I have a problem in which there are two water tanks with different pressure. If they are connected together, how to calculate the time it takes to arrive to the steady state(same pressure)?
Thank you.
Hydrodynamics
:smile:Have you tried Poiseuille's law? Does this sound familiar - the total volume of liquid which flows across the entire cross-section of a cylindrical tube in time? See link http://en.wikipedia.org/wiki/Poiseuille's_law
Thank you for the reply.
The detail of the problem is that two tanks have pressure 87psi and 40 psi respectively. The 40psi tank connects to the water main. The 87psi tank has a expansion tank connected. When they are connected together, is it possible to know how pressure in the 87psi tank change with time?
Thanks for any help.
hi zax,
The flow of water is restricted by the various pipe lengths, fittings and valves you have installed between the tanks. The change in pressure is also a function of the thermodynamics of the air in the tank and heat transfer.
Look through this post https://www.physicsforums.com/showthread.php?t=221054"to get a general idea of some of the concepts and what you might do to calculate things. In your case you might want to simplify the heat transfer and thermodynamics a bit. If you need help understanding flow restrictions, check the attached. Generally in industry, we use the Darcey Weisbach equation as indicated on the attached.
  • Pipe-Flo Pro.pdf
Q_Goest said:
hi zax,
Look through this post here to get a general idea of some of the concepts and what you might do to calculate things. In your case you might want to simplify the heat transfer and thermodynamics a bit. If you need help understanding flow restrictions, check the attached. Generally in industry, we use the Darcey Weisbach equation as indicated on the attached.
What if there was no heat transfer just 2 cold water tanks at atmospheric pressure and both tanks were say a head pressure of 30psi? What would be the best claculation method to ensure both tanks draw water at the same time and not have one tank draw down before the other one starts its draw down?
All you should need to do is to ensure the irreversible pressure drop in the pipe from each tank to the point where the two lines connect is relatively small. The best way to do this is to use lines large enough so that given your highest expected flow through those pipes, the flow restriction is small. In the case of a 30 psi head tank, you might for example try to minimize the irreversible pressure drop between the tank and T to a few psi or less. The smaller you make this pressure loss, the closer the tanks will come to emptying equally.
Once you get to the T in the line that connects the 2 tanks, it no longer matters how much restriction you put in the line downstream of that T.
Note that this assumes the tanks are at the same elevation. If that isn't true, you may have to actively control tank level.
Awsome so bascially ballancing the pressures at were the Two lines connect. Does the cross sectional venting associated with the Tank have to be at least 1-1/2 the cross sectional diameter of the discharge piping configeration in order to flow correctly should this be calculated as well or does it matter. One more thing if a pump is attached to this configeration does accelerated suction velocities need to be accounted for to ensure the ballanced pressure at the connection point of the lines connecting the two tanks?
Thank You for the reply it is great information
Not sure what you mean by the "cross sectional venting". Are your tanks enclosed such that they need a vent? Or are you referring to the liquid discharge lines? In any case, I'd suggest performing a flow analysis on every line so there are no surprises.
I would always do a flow analysis including any acceleration losses to ensure adequate NPSH to the pump. Basically, add the irreversible flow losses into the equation for head and acceleration losses as shown by equation 16 of the manual I posted above.
Thank You for the information
Thank you for the information
1. How do I connect two tanks together?
To connect two tanks together, you will need to use a pipe or hose to create a physical connection between the two tanks. The pipe or hose should be securely attached to the outlet valve of one tank and the inlet valve of the other tank.
2. What tools or materials do I need to connect two tanks together?
You will need a pipe or hose, as well as connectors and clamps to secure the pipe or hose to the tanks. You may also need a wrench or pliers to tighten the connectors and clamps.
3. Can I connect tanks of different sizes together?
Yes, you can connect tanks of different sizes together as long as you have the appropriate connectors and fittings to create a secure connection. It is important to ensure that the tanks are compatible and the larger tank does not overpower the smaller tank.
4. What is the purpose of connecting two tanks together?
Connecting two tanks together can increase the total volume of liquid or gas contained in the tanks. This can be useful for applications that require a larger quantity of the substance, or for providing a backup supply in case one tank runs out.
5. Are there any safety precautions I should take when connecting tanks together?
Yes, it is important to follow proper safety procedures when connecting tanks together. Make sure the tanks are clean and free of any debris or contaminants. Also, ensure that the tanks are securely anchored and there are no leaks in the connection. It is also important to follow any specific safety guidelines provided by the manufacturer of the tanks.
  • Mechanical Engineering
