| New Reply |
how to solve this 2nd order nonlinear differential equation |
Share Thread | Thread Tools |
| May15-08, 07:56 PM | #1 |
Hello all,
This is the first time Ive stumbled across this site, but it appears to be extremely helpful. I am a meteorology grad student, and in my research, I have run across the following 2nd order non linear differential equation. It is of the form: y'' + a*y*y' + b*y=0 where a and b are constants Can this equation be solved analytically? If not, what program does one recommend for solving it numerically? There is also a slightly more complex form of this equation: y'' + a*y*y' + b*y=c where a, b and c are constants If anyone could assist me in solving this or direct me to a source for solving it numerically, it would be most appreciated. Thanks, --tornado |
| May15-08, 08:26 PM | #2 |
Try the substitution y' = u to reduce it to a first order system of two ODEs. (Source:Tenenbaum/Pollard)
Ie., your first ODE becomes the system y' = u, uu' = -ayu - by, where in the second eq. u is treated as u(y) and u' = du/dy, which we can then plug into the first equation to integrate for y(x). The second equation is separable, so there is a straightforward analytic solution. |
| May15-08, 08:43 PM | #3 |
Im not following you. Could you go into a let more detail if possible. Thanks, --tornado |
| May15-08, 09:27 PM | #4 |
Recognitions:
Assuming y is function of x, y' = u. u' = d^2y/dx^2 = d/dy (dy/dx) dy/dx by the chain rule. This is equivalent to u du/dy. Hence u' = u du/dy.
After substituting for y' = u, the ODE is u' = -ayu - by. Replacing u' with u du/dy gives: u du/dy = -y(au+b) This equation is separable and hence solvable. Once you have u(y), you have dy/dx = u(y), which is again separable and solvable. |
| May15-08, 10:05 PM | #5 |
I understand how you get: u' = -ayu - by when you set y'=u I dont understand how u'=u du/dy . I appreciate you trying to work me through this. Any additional explanation would be appreciated. Specifcally, how is this so: |
| May15-08, 10:55 PM | #6 |
Recognitions:
That follows from the chain rule.
[tex]\frac{d^2y}{dx^2} = \frac{d}{dx} \left ( \frac{dy}{dx} \right ) = \frac{d}{dy} \left ( \frac{dy}{dx} \right ) \ \frac{dy}{dx}[/tex] Replace [tex]\frac{dy}{dx}[/tex] with u. |
| May27-08, 10:58 AM | #7 |
[tex]\frac{u}{a}-\frac{b}{a^2}ln[|{au+b}|]+C_1 =-\frac{1}{2}y^2 + C_2 [/tex] So then we need to make the above equation u=u(y) correct? Since we have a ln (natural log), is this possible? Any more help is most appreciated. Thanks, --tornado |
| May29-08, 10:24 AM | #8 |
anyone care to comment on the solution?
| Jun2-08, 02:26 PM | #9 |
anyone???
| Jun2-08, 02:38 PM | #10 |
[tex]au+ b= C'e^{-\frac{y^2}{2}}[/tex] where C'= aeC. |
| Jun2-08, 09:32 PM | #11 |
Recognitions:
[tex]u' = \frac{du}{dx} = \frac{du}{dy} (\frac{dy}{dx}) = u \frac{du}{dy}[/tex] That's where the u/a term comes, once you do long division of u/(au+b). |
| Jun4-08, 03:34 PM | #12 |
How do you rewrite u in terms of y only? Can it be done? |
| Jun4-08, 09:18 PM | #13 |
Recognitions:
Honestly I have no idea if it's possible. It never occurred to me earlier because I didn't actually attempted the DE itself, I just noted it would be solvable if such could be done.
| Jul28-08, 03:12 PM | #14 |
| Jul29-08, 12:29 AM | #15 |
Recognitions:
Actually he was referring to this post:
| Apr22-10, 10:22 PM | #16 |
Does anyone can help me to solve this second order non linear ODE:
y'' + (2/x)(y') - (1/2y)(y')(y') = K, y' = dy/dx y'' = dy'/dx y = y(x) I've already guess y=Ax^2 satisty this equation, but I want to solve it analitically.. Please help! Thank before.. |
| Dec12-10, 06:07 PM | #17 |
Hi,
I'm trying to solve y''(t) + w02 y(t) = k y(t)2 sin(w t). Does anybody know, how to get a particular solution? Thanks. |
| New Reply |
| Thread Tools | |
Similar Threads for: how to solve this 2nd order nonlinear differential equation
| Solution to 1st order nonlinear differential equation | Differential Equations | 14 | ||
| second order nonlinear differential equation problem | Introductory Physics Homework | 17 | ||
| Solving a first-order nonlinear differential equation. | Differential Equations | 11 | ||
| How do you solve this nonlinear first order DE | Differential Equations | 13 | ||
| Nonlinear First Order Differential Equations | Calculus & Beyond Homework | 22 | ||
