Register to reply
Iron bar bending force
by cooper1
Tags: geometry, material, physics, solid
Share this thread:
cooper1
#1
Jun13-08, 08:05 PM
P: 1
Given an iron bar, of round cross-section, fixed by its extremities
(bar measures 152 mm in length and 4.8 mm in diameter),
a weight of 88.5 kgs is hung from its middle, bending it at least
90 degrees.
How much weight/force would be needed to bend another
bar of the same material and size, but of hexagonal or square
section?
2. Relevant equations
Torque = Force * R
Sin(90) * R
3. The attempt at a solution
Haven't got any idea. There should
be something lacking in the text or
more probably some calculus skills
given as knows and hence omitted.
Hope you could clear up this question,
thank you in advance
Phys.Org News Partner Science news on Phys.org
FIXD tells car drivers via smartphone what is wrong
Team pioneers strategy for creating new materials
Team defines new biodiversity metric
Irid
#2
Jun30-08, 01:27 PM
P: 208
I'm not sure, but I think that you need a second moment of inertia over here, which is defined as
[tex]I = \int r^2\, dA[/tex]
where the are is perpendicular to the axis of bending. The bigger this moment of inertia is, the harder it is to bend or deform the beam, so you just use proportion to find what you need.
Register to reply
Related Discussions
Shear force bending moments diagram help? Introductory Physics Homework 2
Bending moment and shear force diagrams Advanced Physics Homework 1
Shear force and bending moment Advanced Physics Homework 1
Shear Force and bending moment diagram General Engineering 2
Statics: Shear force and Bending Moment Introductory Physics Homework 3
