Dynamic Equilibrium Question (block sliding on wall)
The discussion focuses on calculating the force required to slide a 2.0 kg wood box down a vertical wall at a constant speed while pushing at a 45-degree angle. The coefficient of friction is established as 0.20. The net forces in both the x and y directions are analyzed, leading to the conclusion that the required push force (F_push) is approximately 23 N. The normal force is expressed in terms of the push force, which is critical for solving the problem.
  • Understanding of Newton's laws of motion
  • Familiarity with friction coefficients and their calculations
  • Knowledge of vector components in physics
  • Ability to set up and solve equilibrium equations
  • Study the concept of normal force in inclined planes
  • Learn about static and kinetic friction coefficients
  • Explore vector decomposition in physics problems
  • Review equilibrium conditions for forces in two dimensions
Students studying physics, particularly those focusing on mechanics and force analysis, as well as educators seeking to explain concepts of friction and equilibrium in real-world applications.
JJBladester
http://i450.photobucket.com/albums/qq230/JJBladester/06_p51.jpg?t=1223753179
The 2.0kg wood box in the figure slides down a vertical wood wall while you push on it at a 45 degree angle.
What magnitude of force should you apply to cause the box to slide down at a constant speed?
I am having a hard time figuring out the normal force in this problem.
I have set the problem up with four forces (f_k (friction), F_g (gravity), n (normal), F_push (push)). I got the coefficient of friction (f_k) as 0.20 from my textbook.
Fnet(x) = F_push(x) + F_g(x) + n + f_k(x)
Fnet(x) = F_push*cos(45) + 0 + n + 0
Fnet(y) = F_push(y) + F_g(y) + f_k(y)
Fnet(y) = F_push*sin(45) + (2.0)(9.8) -[0.20*2.0*(sin(45)]
I know that the normal force acts perpendicular to the surface, so their should be no n in the y-direction. I'm stuck in finding the normal force in the x-direction and I believe this is the missing link in me figuring out this problem.
The 2.0 wood box in the figure slides down a vertical wood wall while you push on it at a 45 degree angle.
I am having a hard time figuring out the normal force in problem 6.51.
Welcome to PF.
Since the angle is 45 degrees, don't you know what the normal force is in terms of the force?
And isn't that really a part of the equation I highlighted and not the 2.0 as it relates to friction?
As in 2.0*(9.8) needs to balance with .2 * F * cos45 as well as the vertical component F * Sin45
LowlyPion,
Thanks for welcoming me to this site and thanks for your guidance.
__________________________________________
The normal force in terms of the push force is F_push*cos45. Using that to find f_k, I think I have the solution.
Fnet(y) = f_k + F_g + F_push(y) = 0
Fnet(y) = 0.20*F_push*cos45 - (2.0)(9.8) + F_push(sin45) = 0
19.6 = 0.1414*F_push + 0.7071*F_push
Therefore, F_push is roughly 23 N.
9K
  • · Replies 16 ·
