How to Find Maximum Spring Compression from Dropped Mass?
In summary, the problem involves a 2.0 kg block dropped from a height of 55 cm onto a spring with a spring constant of 1960 N/m. The goal is to find the maximum distance the spring will be compressed. The solution involves setting the gravitational potential energy of the block equal to the potential energy of the compressed spring and solving for x. However, the maximum spring compression occurs when the spring has absorbed all of the block's mechanical energy, not just its potential energy. Therefore, the total mechanical energy of the system, including the potential energy of the block and the compressed spring, must be considered. By setting the initial total energy equal to the final total energy, the correct equation for finding the maximum spring compression is obtained
emilykorth
A block of mass m = 2.0 kg is dropped from height h = 55 cm onto a spring of spring constant k = 1960 N/m (Fig. 8-36). Find the maximum distance the spring is compressed.
PEspring=1/2 kx2 F=-kx PE gravity=mgh KE gravity=1/2mv2
I started by setting PE gravity equal to PE spring so that mgh=1/2kx2.
so then I had (2)(9.8)(.55+x)=(1/2)(1960)((.55+x)^2)
I then solved for x and got x=.55 but this was wrong-why?
The maximum spring compression occurs when the spring has absorbed all of the block's mechanical energy, not just it's potential energy.
so how can I vary the equation to make it right?
mgh+1/2mv^2=1/2kx^2?
The initial gravitational potential energy is certainly mgh, but should it have a gravitational potential of -mgx when the spring is compressed a distance x?
Try looking at the total mechanical energy of the whole system, KE_block+PE_gravity+PE_spring...what will be the kinetic energy of the block when the spring reaches maximum compression? What will be it's gravitational potential energy? What was the initial total energy of the block?
When the spring reaches maximum compression there would be no kinetic energy since the block will eventually have no velocity and will stop. Would the KE of the spring be Wspring=-1/2kx^2?
the KE of the spring is negligible since it is assumed that the spring's mass is very small, so you can ignore it (KE=mv^2/2 remember).
The KE of the block will indeed be zero at the maximum spring compression, what will it's gravitational potential be?
mgh?
gravitational potential of the spring-would it be 1/2kx^2?
mgh is the potential energy of the block before it is dropped
when the spring is compressed a distance x, how high is the block (assuming that the height of the uncompressed spring is zero)?
it would be -x which is what I am trying to find
Right, so the gravitational potential energy of the block at maximum compression should be -mgx correct? So what is the total energy of the block and spring at maximum compression?
yes but wouldn't the gravitational PE of the block involve the height that is given since the block is traveling not only the height but the distance that the spring is compressed? so wouldn't that be mg(h+x)?I have no idea what the potential energy of the block and spring would be when compressed-Im so confused!
The initial total energy of the system is mgh (since the spring is uncompressed and the block has no initial kinetic enrgy)
The final total energy is the sum of the gravitational potential of the block at it's new height (-x) and the potential of the compressed spring (1/2 kx^2)
Since total mechanical energy is conserved, the initial total energy will equal the final total energy; hence
[itex]mgh=-mgx+\frac{1}{2}kx^2[/itex]
Do you understand?
ok yes i think so...so when a spring is compressed it has just PE
thank you
so is h just the h given or would it be h+x?
h is just the h given.
What is spring compression?
Spring compression is a measure of how much a spring has been compressed from its original length when a force is applied to it. It is typically measured in units of distance, such as meters or inches.
What factors affect spring compression?
The amount of force applied to the spring, the stiffness of the spring, and the length of the spring are the main factors that affect spring compression. Other factors may include temperature, material properties, and the shape of the spring.
How is spring compression calculated?
Spring compression can be calculated using Hooke's Law, which states that the amount of compression is directly proportional to the applied force and inversely proportional to the stiffness of the spring. The formula for this is F = kx, where F is the force, k is the spring constant, and x is the amount of compression.
What are some common methods for measuring spring compression?
Some common methods for measuring spring compression include using a ruler or measuring tape to directly measure the change in length of the spring, using a force gauge to measure the force applied to the spring, and using a displacement sensor to measure the amount of compression.
Why is it important to find the spring compression?
Finding the spring compression is important for understanding the behavior of the spring and its ability to store and release energy. It is also useful for designing and testing various mechanical systems that use springs, such as car suspensions, door hinges, and shock absorbers.
