Thread Closed
Projectile motion, need to find angle
Share Thread Thread Tools
Oct14-08, 01:28 PM   #1
A cannon with a muzzle speed of 1009 m/s is used to start an avalanche on a mountain slope. The target is 1900 m from the cannon horizontally and 795 m above the cannon. At what angle, above the horizontal, should the cannon be fired? (Ignore air resistance.)
2. Relevant equations
I'm thinking this equation is my best bet, yf = tan(angle)xf - (g/(2 * vi^2 * cos^2(angle))) * (xf^2)
3. The attempt at a solution
since I know the vi, xf, and yf, I was able to plug everything in and reached 795 = 1900tan(angle) - 17.375/cos^2(angle). This is where I am stuck. I tried several times but could not find a way to solve for angle.
I would really appreciate it if someone could point out how to solve for the angle in my problem. Or is there a totally different way of solving this problem?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Oct14-08, 02:24 PM   #2
Recognitions:
Gold Membership Gold Member
Your work DOES look great (I checked your first equation). The problem is that you've got an algebraically difficult thing to solve for (the angle) because it's inside trig functions.
What I suggest is keeping your equation in terms of the components. Relate one of these components ONLY to the initial speed and the remaining component. Then solve for the component you kept. You can use this solution to find the angle.
Added at a later edit: You could also just graph your second function and look for where it crosses zero, but that's easy only because of modern graphing tools.
Oct14-08, 06:26 PM   #3
thank you for your input, i separated my problem into x and y components:
x component ---> 1900 = 1009cos(theta) * t
y component ---> 795 = 1009sin(theta) * t - 4.9t^2
I used my x component to solve for cosine
1900/1009 = cos(theta) * t
cos(theta) = 1.883/t
I then used trig identity sin^2(theta) + cos^2(theta) = 1
sin^2(theta) + (1.883/t)^2 = 1
sin(theta) = square root(1 - (1.883/t)^2)
then I plugged sin(theta) equation into my y component
795 = 1009 * square root(1-(1.883/t)^2) * t -4.9t^2
I think I'm on the right track but I don't really know where to go with this, it's not really a quadratic equation and I don't know what to do now. Any pointer would be greatly appreciated.
Oct14-08, 06:57 PM   #4
nm, I got it. Thank you for all your help.
Thread Closed
Thread Tools
Similar Threads for: Projectile motion, need to find angle
Thread Forum Replies
Projectile Motion given angle and distance, find intial velocity Introductory Physics Homework 5
[SOLVED] Projectile Motion - Ramp Angle Introductory Physics Homework 5
Find angle (Projectile Motions) Introductory Physics Homework 7
projectile motion - no angle given??? Introductory Physics Homework 2
projectile motion at an angle Introductory Physics Homework 2
