Deriving equation to describe lattice vibrations of a one dimensional crystal
peterjaybee
When setting up this derivation one assumes a chain of identical atoms. The interatomic interaction between atoms is short ranged and so only affects neighbouring atoms (see Hook and Hall, "Solid State Physics" chapter 2.3.1).
The potential V(r) is expanded as a taylor series about r = a to give,
V(r) = V(a) + (1/2)(d^2V/dr^2)(r-a)^2 + ...
1) I am just taking it as read that this is true but i don't understand why V(r) can actually be expanded it like this (I just can't get my head around the problem, and the lecture notes and formentioned book do not go into detail or show any steps leading up to this equation). Can anyone explain or show why you can use this expansion?
2) The dV/dr expression in the expansion is dropped "because the first derivative must vanish at the equilibrium spacing where V(r) is a minimum" - Hook/Hall again. Can anyone explain this in a different way because once again it has gone over my head?
Many thanks
Peter
We can derive the fomula
as follow:
We write
V(r) = V(r - a + a)
where a is the equilibrium position of a particle. We assume that the displacement of the particle with respect to the equilibrium position is very small, so we can expand:
V(r-a+a) = V(a) + (dV/dr)(where r = a)* (r-a) + second order + ...
you see a is the equilibrium position of particle, so it corresponds to a minimum V(r) --> derivative = 0
that means the coefficient of (r-a) is zero.
cheers,
Thankyou
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
